The Weighted Companion Cube Will Never Threaten To Stab You And, In Fact, Is A Subwoofer
From the techPowerUp! forums comes an awesome weighted companion cube subwoofer built by the metonymical user named [Cube].
This build started off as a coffee table that was to have an oval glass top (no word if the edges were going to be blue or orange). The guts of the cube are taken from a 400 Watt sub. As any good sub builder would, [Cube] kept the air volume and port tuning of the donor box.
We’ve seen a companion cube sub before that featured EL wire for a ‘glowing cube’ effect, but [Cube] may have taken things a little too far by including glowing rings on each side of the cube. The rings lit by 2,500 LEDs mounted on pieces of perspex and wired point-to-point. While [Cube] claims he’s ‘not a electronics guru,’ he certainly has a lot of patience to assemble those lights.
Check out [Cube]’s YouTube build video after the link. Credit to [Todd] for sending this one in.
[youtube=http://www.youtube.com/watch?v=gOyz4w9Mq0E&w=470]
12 thoughts on “The Weighted Companion Cube Will Never Threaten To Stab You And, In Fact, Is A Subwoofer
  1. What if an LED fails? He covered them with glue. I’m not an expert but I think he should have considered that. With some many LEDs failure is not far away. Also having them hooked up on some kinda animation circuitry would be cool. But anyways great mod.
Leave a Reply to FuzzyCancel reply
