Do you have a rooted Android device and a computer running Linux? If so, you’re already on your way to coding for Android in Assembly. Android devices use ARM processors, and [Vikram] makes the argument that ARM provides the least-complicated Assembly platform, making it a great choice for those new to Assembly programming. We think his eight-part tutorial does a great job of introducing the language and explaining how to get the development tools up and running. You’ll need to know some basic programming concepts, but from what we saw you don’t need any prior experience with ARM or Android.
So why learn Assembly at all? We took a stab at Assembly for AVR a few months ago and really learned a lot about the hardware that we just never needed to know writing in C. It’s a great way to optimise functions that waste too much time because of quirks with higher-level language compilers. That means you don’t need to write your entire application in Assembly. You can simply use it to streamline hairy parts of your code, then include those Assembly files at compile time.
Subscribe for weekly videos
If you’re coding in ASM, you’re not writing an Android app anymore…unless I’m missing something?
there is a lot of types of assembly… Each processor has his own type of assembly
x86 is the assembly for Intel processors for example
I meant more that “Android” refers to the abstraction that apps run on, whereas coding in ASM for these devices would mean writing an ARM application, but not one that would necessarily run on the Android framework.
At this point I haven’t really done much Android coding but don’t different devices have different processor architectures? Will you assembly app run on any Android device?
Not even close! I’m not that crazy! I haven’t even used assembly lang for 8 bit micros for a looong time.
Nice project, but I don’t agree that ARM provides the least-complicated Assembly platform. RISC doesn’t make it easier for programmers to implement a given algorithm and the pre-/post-shift and other modifiers for the ARM instructions makes it more difficult to use the right instruction. The x86 instruction set is a CISC instruction set, but you are right, it is complicated, too. Take a look at the 6502 or 68k instruction sets, which I think are much easier to use for human beings, if you don’t have a built-in compiler and optimizer in your brain :-)
Isotope, you are missing something.
You have two options: Call streamlined asm functions from regular android code, or call android code from an asm application. The end user should be completely oblivious to the difference.
I think PIC definitely provides the least complicated assembly platform. Considering some devices have very low instruction counts 35 on the ol’ 16f84a and a very simple architecture. Compared to ARM which has very many, and newer cores have various cool things like ThumbEE. Some features are only usable with secret codez.
Arm assembly is very worth while learning and becoming proficient in since it’s likely to become more popular in the main computer market. And we need to get better at exploiting it.
You should define “least complicated assembly platform” in more detail: Of course, if there are just 35 instructions, as in some cheap PICs, it might be easy to learn all instructions, but how difficult is it to write programs with it? Take a look at the programming language COW (I’ve written a JavaScript interpreter for it: http://www.frank-buss.de/cow.html ). It has only 12 instructions, each one very easy to understand, but it is very difficult to implement something useful in it, and more important, much more difficult to understand what some code does by just reading it. Same for ARM: I’ve seen a nice FFT implementation in ARM, but even with very good commented source code, it is very hard to understand how it works.
The PIC16F84A was the first mcu I ever used, and it’s assembly the first language I ever learnt. All from this http://www.mstracey.btinternet.co.uk/pictutorial/picmain.htm There are very few languages and architectures that you can learn so comprehensively so quickly.
It’s fairly easy to write programs in, I’m hardly a master genius.
I agree with Frank Buss…
Knowing the instructions is not a problem as far a
Knowing the instructions is not a problem as far as you have the instruction list clearly explained and I prefer one instruction to do something instead of 3 or more.
Moreover, RISC processors are really interesting when they can offer a one clock cycle instruction… If too few instructions are implemented, there’s no interested at all. THis problem is common to PICs and low-end MSP430 for example.
[mode mylife] I learnt “assembler” on 68000 and switched to AVR then. It took me one week only to implement a fully functional app from zero[/mode mylife]
Except those that don’t. There are at least MIPS-based devices and Intel will be releasing their own port. By not using the virtual machine you’re effectively splintering the Android platform.
X86 android devices are already shipping .. the Logitech Ruvue is one of them.
@original article
You can’t yet write an “Android Application” in 100% native code (I think the next version of NDK will make that possible), and even if you could most of the APIs you want aren’t available from native land unless you target 2.3 only.
And.. I cant see any reason you couldnt do inline assembly for Android using the NDK anyhow.
“Have you got what it takes to code Android apps using Assembly?”
No, no I do not.
Uhh… ARM Assembly is nowhere _near_ the easiest assembly language. Take a look at MIPS, which is much simpler, or even x86 (which has a few flaws).
Oh my god, I drooled the first second I saw ARM assembly on the RSS reader image ! I hope some seriously kick ass ARM and thumb skills are coming !
ARM is easy because all IP cores are flashed with initialization and management code at the factory, this includes consumer/hobbyist OMAP chips..To get to mess with the actual interesting stuff you gotta pay big money for one of the handset cores, and get special licensing. Unless you find memory corruption in certain parts of the kernel or boot chain on consumer devices.
I actually did a paper on Trustzone before iphone and other products existed. RISC based I/O controllers are actually better to learn with, radioshack use to sale one..
I don’t even understand what you’re saying. If you want to write all code from power-on onwards just buy a microcontroller board for $20. Even most application processors only have enough built-in capabilities to load a sector from NAND flash, the rest is up to you.
“I don’t even understand what you’re saying”
ok…everything has a loader ROM unless you do special licensing and factory flash your own..like I said..OMAP and others have USB and a lot of other stuff paged just in the first stage loader..
A program written for one Android phone in ASM won’t necessarily work on another Android phone. Not to mention Android runs on Intel…..
“use it to streamline hairy parts of your code” – I LOLd. “When hairy turns messy” XD
There is a huge , make that monstrous, lack of people learning ASM. Sure you can write code with C or others but what do you do when that code doesn’t work like it should ? When the compiler has an error or the library you depend on doesn’t work ? Without knowing ASM you can’t use the debugger, that spits out things like registers and opcodes. You can’t go to the data sheet, that is talking about the same kind of things.
I really have no respect for hardware developers that don’t understand ASM. Without knowing ASM you are just relying on other peoples software and will never be able to fully use the hardware.
Maybe because it isn’t useful for the vast majority of development that is now done in high-level languages with frameworks and large “standard libraries”
http://www.gnu.org/s/gdb/
You ask the people that have written the compiler.. ARM, Intel, Renesas do have people involved with GCC. I would rather they fix compiler level issues like working around chip errata, pipeline bugs than someone that think they are an asm h4x0r.
The only thing I can think of that you would need asm level debugging for is startup code.. source level debugging is more useful for fixing most issues.
GDB is source level.
Only if you ask it too do a disassembly or something. GDB has no problem working with source.
Android’s NDK has support for GDB.
The software manual for your chosen chip will tell you all the opcodes etc.. if such documentation didn’t exist no one could write assemblers or compilers.
I have no respect for people that think they know better than the compiler. Do you fully understand the pipeline? are you 100% sure your “efficient”/”pretty” inline asm isn’t actually slower than the stuff your compiler is generating?
Unless you are very space constrained the only asm you need on ARM is maybe some in your crt0 (your toolchain vendor should supply it) and maybe some for ARM specific stuff like reading the status register. Any asm you use should be for very specific tasks.. there is no point writing asm that calls libc functions. On Android 2.2+ (IIRC) Dalvik has a JIT anyhow.. so there is even less point to this.
i agree with cgimark, I would feel weird writing anything in C if i didn’t already have a handle on ASM for that chip. no respect
Did i miss simething? Should this article be titled Coding debian apps using assembly and executing them on a phone that has debian installed on it?
no, nobody bothers coding anything low level anymore.. This is just common paged/kernel-managed development.
