This little beast is named Mechatron. Built by a father/daughter team called Beatty Robotics, the goal was to build something “retro-futuristic, tough, and industrial”. We think they definitely pulled off some of their goals here. Weighing in at nearly 50 pounds, Mechatron is still very agile, as you can see in the video below. He can fire his gun, which uses brass or plastic bullets, at a rate of nearly 1,000 rounds per minute while traveling in any direction thanks to the use of the mechanum wheels. 8 range finding sonar sensors, a laser and a turret that rotates 360 degrees will make sure you don’t elude Mechatron’s watchful eye… and shooting. While we were initially debating how they could make the Mechatron look more reto-futuristic, we all agreed that the lights in the video helped a lot. Maybe a curvy body piece could help too, depending on what era they were hoping to achieve.
[via buildlounge]
Subscribe for weekly videos
This is so, cool! I really want one to guard my appartment while I’m gone… would definitely be super-effective against robbers!
Now, one little concern: if you live in an appartment, your downstairs neighbours will hate you for having this roam on the wooden floor… it make a hell of a noise!
Ok, the sonar sensors and omni wheels are impressive. So are the maneuvering patterns, like strafing in a circle. If they slave this thing to a remote “brain” they could really get into some interesting AI experiments. Or Swarm logic if they build anymore.
Put on better wheels and mount an M4 and the government will pay you $100,000 each for a million of them!
Love the idea of taking an airsoft mechbox with a shortened barrel for firepower.
Those wheels are awesome. I love that concept of strafing by using diagonally-treaded roller-wheels.
Also, there’s something weird with the way HAD is embedding Vimeo vids. I can see it fine on the build page, and on the Vimeo page, but the HAD one won’t even load.
Works for me. The youtube embeds often get screwed up, but they fix them fairly quickly. Maybe that’s what happened here.
I love the concept. I want two!
Wow,that’s awesome.The strafing movement looks like robot’s moon walk.
How did you get those wheels? I’ve seen plastic ones, but aluminum… :-0 awesome.
I am pretty sure those wheels are from AndyMark. I see a lot of FIRST Robotics team use them.
Bad. Ass. Two things I really like about this. The fact that it is a father/daughter team is really cool because we definitely need more women in engineering. Second, those wheels are really cool and already got me thinking…
What’s the runtime on this though? I imagine it’s pulling a lot of amps running all of that equipment at once.
Those are called “Mecanum” wheels or “Swedish” wheels. It looks like they’re using wheels from AndyMark. http://www.andymark.com/category-s/53.htm
This is so sick. I love it!. I would mount a better airsoft gun to it and take it out to my next match. lol
How do the wheels work on other surfaces? Does dust, or small stones, or maybe mud have any sever impact? (provided that the terrain is sufficiently flat of course)
We use them on carpet day in and day out without issues. Now for a particle surface I would believe that the strafe functionality of the wheels would be null. The way the strafing works is by rotating the front wheels the opposing direction of the rear wheels. A particle surface would just get pushed out of the way (like a car stuck in sand) and would dig down.
Now if you redesigned the wheels with a hard material with diagonal groves instead of rollers then you could in theory travel in the particle or even a moderately deformable surface (like a high pile carpet) with less dig and more slide.
@All who don’t know the wheels are Mecanum design. With proper controls you can move in 3 degrees of freedom on a surface (Forward/Backward Rotate and Left/Right). They are great for mobility but no so much for pushing power. If you try to push something the rollers will .. well roll reducing your max forward force to that of the friction of the individual rollers on their carrier. That being said you could adjust the friction of each of the rollers but then you loose power strafing.
Looks like a version two airsoft gearbox. I like the feed tube extension to the chamber.
Nice work. I award thee TWO (2) internets.
retro-futuristic just sounds like an oxymoron, but it makes sense when you think about it (what people in the past though was futuristic)
“reto-futuristic”? fins on the rear fenders, especially the 58-59-60-61 Chevy variety front because most forget about those,front bumper with “boobies”, nose cone in the center of the grill. 57 Chevy hood ornaments. I guess any auto styling element from 1950-1961 could be put to use. A 59 Caddy in it’s entirety would be far out, but so much work.
I have used mecannum wheels on a ~200lb chassis outdoors and with enough torque you can strafe on nearly any surface.
We used andymark wheels (looks like that might be what this robot has as well): http://www.andymark.com/category-s/98.htm
Strafing on grass drew 150A 26V though.
I hope to make my own wheels using sealed bearings instead of bushings. They get gummed up very quickly as soon as you go outside.
Just need to add a wireless camera
Where are the bullet holes, the video shows everything but the one part I want to see: how lethal it is.
Have they tried to defeat this yet?
I mean, by things like putting a backpack between the muzzle and the target. Or tossing a heavy thing on top from an elevated position. Or holding up a sheet to show up as neutral to the sonar. Or by having two assailants with shields of sheet metal, plywood, etc. and things for overturning the robot from a position of advantage.
It surely sounds impressive… for a prototype.
…laws of robotics?!
Resemblance to the Metal Slug Tank.
I was hoping for something like the ED 290 in Robocop. Or at least something that looks intimidating like the bots from robot combat league. I guess something that big doesnt work for home security. But come on, looks like you could kick this thing on its side and render it useless
