The International Obfuscated C Code Contest Is Back
The International Obfuscated C Code Contest is back. The stated goals of the IOCCC are to, “Write the most obscure C program, show the importance of programming style (by doing the opposite), stress the preprocessor to the breaking point, and illustrate some subtleties of the C language.” If you think you’re up to the task of abusing your compiler, check out the rules and guidelines for the contest.
There’s nothing quite like having the code for a flight simulator look like a plane, or calculating pi by measuring the area of C code. The submissions to the IOCCC are classic hacks; very clever things that shouldn’t work, but do despite themselves.
There hasn’t been an IOCCC competition since 2006, and no one knows if it will be around next year. We’ve already seen a few potential entries for this year, like piping chars into /dev/audio to generate a song and hyperlinks all the way down. If you’ve got something you’re working on, feel free to send it in.
via /.
13 thoughts on “The International Obfuscated C Code Contest Is Back
Leave a Reply to DroneCancel reply
