DIY dimmable clapper for all your lazy lighting needs
For the lazy man who can’t be bothered to buy a proper wattage lamp here’s the Clever Clapper, a Clapper that finally has the ability to dim the lights.
Like the clapper we saw last month, [Pete]‘s version uses an ATtiny2313 and an electret mic. What sets [Pete]‘s version apart from the vintage 80s model is the ability to dim the lights. Like any clapper, two hand claps within a second toggles the relay. Clapping three times within one second puts the lamp into fading mode. In this mode, the lights dim up and down with PWM until a fourth clap is detected.
[Pete] saw that the program memory in his ATtiny2313 wasn’t 100% full, so he added a few more capabilities. If you shine a laser onto his circuit, a relay trips and turns on a decorative moon lamp. There’s also a ‘lecture mode’ that feeds the microphone directly into the microcontroller to vary the PWM signal. The result is a light that brightens with more intense sound. Check that feature out after the break after the demo video of [Pete]‘s Clever Clapper.
Comments
  1. Mental2k says:
    I followed it fully up until the word “sadly” after that it’s all a bit wtf!
  2. Per Jensen says:
    And that´s “Electret”….
  3. N0LKK says:
    I like the old school way of including art work in a video, we saw in the first video. I like the lecture mode as an alternative way to building a light organ. Used explore to save Pete’s blog as a mht file. I wish Firefox has a similar way to say to save a web page as a single file.
  4. zokier says:
    He is doing PWM with a relay? Sounds bit odd imho..
  5. That is an excellent device. Very well made and very aesthetically pleasing. Thanks for posting!
  6. fartface says:
    Why does the summary contain the word “relay” when the circuit it’s self does not even use one?
    • Steve-O-Rama says:
      It does use a relay. Follow pin 8 (T0/PD4) from the micro-controller; you’ll see it’s attached to a series resistor, and then a 2N3904, to switch the coil current of the relay.
  7. Steve-O-Rama says:
    I kinda rolled my eyes after seeing so many dollar signs on the EAGLE schematic. It’s mostly an aesthetic thing, I know (but don’t even get me started on AdaFruit schematics…).
    Another item of concern: TIP120, which are Darlington-configured bipolar NPNs. Aren’t those a bit antiquated? I’d think using some good logic-level MOSFETs (or maybe even a MOSFET driver if you really wanna drive ‘em hard) would be much better in terms of power dissipation and current handling capabilities.
    Other than that, not too shabby. I dig the simplicity of the LPF used. :)
    Note: I tried an XHTML tag in my message, so if it didn’t work, please don’t crucify me.
  8. shubhankar says:
    can’t i use tip122 instead of tip 120?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
