Control MIDI with an Android device
[Lewis] wanted to control MIDI devices with the huge touch screen that is his Android phone. After he couldn’t find a simple hardware implementation of MIDI out, he turned to an IOIO board to send MIDI notes to just about any imaginable musical hardware. It’s a clean build and fills a gap in the abilities of the Android platform.
Because of the woeful support of MIDI in Android, [Lewis] couldn’t find a good way to push MIDI notes from his phone to other devices. While there are a few high-overhead options like MIDI over wi-fi or a Bluetooth connection, there wasn’t much in the way of a straight-up hardware connection to other MIDI devices. [Lewis] got around this limitation by using an IOIO board and the right software to send MIDI notes though a DIN-5 connector.
Although the project works as intended, [Lewis]‘ build could be made more permanent by building one of these MIDI interfaces and wiring that to the IOIO. All the Android code is up and available, along with a neat demo of [Lewis] controlling the delay time of an effects unit in his guitar rig. You can check that video out after the break.
Comments
  1. anti says:
    Bad idea and will probably kill your IOIOI pretty soon.
    There is a reason why the specs mandate galvanic isolation for MIDI interfaces.
    I killed more than one arduino ignoring this.
  2. Some truly prize articles on this website , bookmarked .
  3. Cameron says:
    Hi,
    i’m new to Android programming, I try to run the midi to tab software below
    http://sourceforge.net/projects/midisheetmusic/
    and light the midi led decoder attached to my Android cell phone
    I’ve check the URL https://bitbucket.org/LBNerdBard/android-midi-example/overview
    and would like to know how I could have them work together
    Thanks
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 94,560 other followers
