[Joby Taffey] just rolled out a serial bootloader for the Chipcon CC1110/CC1111 processors. The project is called CCTL and aims to make prototyping with the Girltech IM-ME a bit less tedious. Up until now firmware for the device had to be pushed in with a GoodFET or TI proprietary programmer which was quite slow. But this bootloader makes it possible to push your code via the chip’s serial port at 115200 baud. But the pretty pink pager isn’t the only device using these chips and to prove it [Joby] send this picture of all the electronics he has on hand running this architecture.
Once the 1KB CCTL bootloader has been flashed to the chip, a serial port or USB to Serial converter can be used as a programmer. [Joby] warns that the Chipcon processors are not 5V tolerant so you need to either use a 3V serial converter or add a level converter into the mix.
CCTL provides the features you’d expect from a bootloader. It uses the chip’s watchdog timer to guard against failure due to broken code. And there is an upgrade mode available at power up. Instruction for use are included in the Github repo linked at the top.
Subscribe for weekly videos
Awesome boot loader. Surprisingly small too. Thanks for releasing it to the world.
Must go and find my Im-me and dongle now. And dig out my 8051 handbook :-)
Awesome work, but what exactly are these “electronics” [Joby] laid out?
I believe those are development boards…
Well sure, but “electronics” doesn’t quite specify that.
http://www.flickr.com/photos/54388270@N04/6790258384/in/photostream
