Last chance to enter The Hackaday Prize.
The Dronitar; a scrap made motorized sitar
This peculiar instrument, called the Dronitar,  is completely made from scrap. Interestingly, it sounds pretty good. You can hear the dronitar in action in the video after the break.The call this a  “2 stringed” instrument,and most who are instrumentally savvy will find a bit of confusion here. They are referring to the string that you play as well as a small string that is struck against the other by a motor to create the droning effect. The result sounds very much like a sitar mixed with a bit of surfer rock styling.  You’ll note that they’re even using a second motor as the pickup!
Comments
  1. em2thrasher says:
    Sounded like he was trying to play Miserlou at the beginning.
  2. Threeck says:
    I’d like someone to make a Sitar Hero. It’s like Guitar Hero, but with only 1 button :|
  3. Zehn says:
    it’s more like a 1 string electric hurdy gurdy than a sitar. http://en.wikipedia.org/wiki/Hurdy_gurdy
  4. Galane says:
    There’s the first person to cast for the “Revenge of the Nerds” remake. ;)
  5. webkraller says:
    I believe there are actually 2 playable strings, as per the video.
    Also in the video it looks like there are two motors at play for the string striking? Unless the spinning in the body is driven by the one in the neck in a hidden way.
    • webkraller says:
      Disregard double motor spin. He clearly states that the neck motor is spinning the string near the pickup.
      • Correct! 2 playable strings, and 2 motors, one is an actual motor and the other I used as the pickup. I had to set the spinning one as far from the pickup one as possible as there’s a lot of noise/interference when they’re close together.
        I routered a groove in the neck to house a piece of strimmer wire that spun underneath the frets and tied to the piece of string that hits the wires.
  6. Glad you liked my work! Thanks a million for writing about it too, very chuffed it’s being written about!
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 91,108 other followers
