Seeing the Venus transit; this is why you should visit your local hackerspace
So I thought about getting a pair of protective glasses so that I could safely stare at the sun during yesterday’s Venus transit. But then it was forecast to be cloudy in the afternoon (the event didn’t start until 5pm here) so I forgot about it and figured I’d try to catch it next time around (which is 105 years from now).
I went about life, ate some dinner, then grabbed my latest project and headed off to the monthly meeting at Sector67, the local Hackerspace in Madison, WI. Lo and behold I arrived to find this sight in the parking lot:
Sure, my priorities may have pushed the viewing to the side. But others made it their mission to see the once or twice in a lifetime event and I got to see it just for being in the same place as them. This is the meat and potatoes of Hackerspaces…. collaboration. A source of new ideas, motivations, and inspirations.
One of the members brought a telescope and went online to figure out how to safely use it for viewing. For about $2.50 he rigged up a funnel covered with a piece of acetate which interfaced with the eyepiece of the scope. The image at the top shows the entire sun, and even though some of the cloud cover can clearly be seen, there’s Venus, plain as day. The cardboard box is just providing a shaded viewing area around the funnel. As with most cosmic experiences, it surprised me by being way cooler than described. See a few extra pictures in the gallery after the break.
[Read more...]
Hackerspace Intro: Chatt*Lab in Chattanooga TN
During our trip through Tennessee, we were able to get a sneak peak into a hackerspace that hasn’t quite opened its doors yet. Chatt*Lab in Chattanooga has just acquired a space and begun putting equipment in. Chattanooga, once called “the dynamo of the south” due to the amazing amount of industry located there, has been in need of a gathering place for like minded hackers for a while. They’ve been conversing through various means on the web for some time, but have finally found a space that suits their needs.
[Tim Youngblood] gave us a tour of what they currently have and shared a little bit of their plans for the future. As you can see in the video, there’s not a whole lot of stuff there yet. There are a handful of nice tools and a very nice looking and rather large CNC machine. However, they have solid plans and determined people, so we expect this to expand soon. On the subject of expansion, this space may seem tiny but that’s only because we shared the active space. The rest of the facility is vacant and available for them to expand into as they grow!
Let this act as a reminder, we don’t care how big or small your hackerspace is, send us a tour and we’ll publish a story on it. On almost every single hackerspace intro, we’ve seen comments where people had no idea there was a hackerspace in their immediate vicinity.
Bossy calendar tells visitors when to go away
So here’s the scenario. You’re the boss and everyone needs to kiss up to you speak with you about important project details. You need a receptionist, or a creative employee who will build a calendar display the lets people check if you’re free to chat. It works by querying a Microsoft Exchange server for the guy’s calendar. The hardware within doesn’t deal directly with the full Exchange API, but relies on a server-side script that feeds it info on request. This is a nice touch since you can do a lot of filtering on the server and keep it simple with the embedded electronics
Speaking of embedded hardware, this uses Gadgeteer modules. You probably don’t remember, but these are Microsoft’s electronic modules aimed at C# and .NET programmers. It uses the main board, and LCD, USB host, and Wifi modules. This is the first project we remember seeing since the hardware was announced.
We wonder if this will change the boss’ behavior? Will he start scheduling creatively so that he gets more time without interruption?
Make your next enclosure out of stone
Sure, a laser-cut plywood enclosure adds a lot of maker cred, and custom plastic or cast aluminum enclosure belies an engineering and design prowess. [ardiyno] didn’t want one of these run-of-the-mill enclosures, so he made one from scratch out of limestone.
The stone [ardiyno] used comes from the southern bit of his native Netherlands. It’s a very nice limestone, easily carvable and capable of very fine detail as seen in [ardiyno]‘s scary/creepy carved limestone bookends.
Inside the enclosure, [ardiyno] has a calendar/clock/environmental sensor displaying the current date, time, relative humidity, and light level on twelve 14-segment displays. [ardiyno] admits the enclosure is a bit oversized for how much space his project takes up, but the extra space is meant for future internal expansions.
After the break, you can check out [ardiyno]‘s method of using a screw driver to carve the limestone. Normally, we’d call foul over someone abusing tools, but the limestone is so soft (the pyramids were made out of limestone using soft copper tools), there’s most likely very little damage to the screwdriver.
via reddit
[Read more...]
Automatic wakeboarding in a pond
[Rick] sent in an awesome project he and his uncle [Charlie] have been working on for this summer. It’s a completely automatic wakeboarding system that tows [Charlie] and company from one end of his backyard pond and back again.
The entire system is supported by two towers at either end of the pond. Strung between these towers is a 420 foot cable that pulls the rider from one end to the other before stopping, and automatically continuing in the opposite direction. Apart from stopping and starting the motor attached to the cable, no user input is required. This means anyone lucky enough to make it to [Charlie]‘s farm can wakeboard all afternoon without a break.
[Rick] posted a few short videos covering the internals of the system. From what we can see, the guys are using a LabJack U3-LV data acquisition unit to grab the speed, direction, and position of the rider. This data is sent to a laptop that controls the motor suspended on one of the towers.
There are a few more videos of this incredibly fun toy available after the break.
[Read more...]
Visual rain sensor — so you never have to look outside
Now you can find out how hard it is raining outside without leaving the confines of your mancave/womancave. Pictured above is the sensor portion of what [Frapedia] calls his visual rain sensor.
Most rain gauges just use a graduated cylinder to capture water as it falls from the sky. That will give you a reasonably accurate measure of how much it rained, but it tells you nothing about how hard it rained. The measurement made here is based on sound. The harder it rains, the lounder the sound will be from water hitting an up-turned metal bowl. The unit above turns the system on when water bridges the traces, then a microphone is used to monitor the sound from the bowl. This is visualized by a VU-meter chip on a column of LEDs mounted inside the house.
After the break you can see the project box that houses the status display. We say it’s too small an needs to be replaced with a much larger LED meter.
[Read more...]
Pneumatic car launcher is actually more than just a hacker’s fantasy
So if you had to launch a car through these goal posts how would you do it? Certainly not with a slingshot (although we might have gone with a steam-powered catapult a-la an aircraft carrier). That maroon car with the white stripe is about to make the flight thanks to a very powerful pneumatic launcher.
We don’t usually attend the demolition derby, so this sort of thing is new to us. And we were even more surprised to find that this isn’t strictly a novelty act. The system is actually how some of the more dangerous automotive stunts are done for the movies. This launch sends the car in a graceful arc that is right on target and reminds us of the cliffhanger stunts from The Dukes of Hazzard (TV, not the recent movie). But if you’re a director looking for a horrific car accident, the rig can be altered to send the car spiraling through the air. Sounds like the record is nearly eight turns while airborne.
We don’t have any extra cars to launch, so we’ll stick to making the confetti fly.
[Read more...]
Follow
Join 91,277 other followers
