Here’s a interesting idea; if the hardware seen above is dropped at a location, you can monitor radio signals remotely via the Internet. [MS3FGX] has been toying with the idea for a little while now. He wanted to use a DVB dongle with a portable Linux solution to offer Software-Defined Radio (SDR) capability without the need to actually be there.
The white box is a PWN Plug, a branded version of the SheevaPlug. The black dongle that plugs into it is a DVB tuner dongle. It’s meant to receive television signals over the radio, but recently the hardware has been used as a simple way to implement SDR. Combine the two (along with the antenna), stir in a network connection, and you’ve got a remote listening post. What can you listen to? Just about anything that’s within the dongle’s bandwidth range. [MS3FGX] mentions walkie-talkie traffic and pager signals, to name just two.
He even wrote an installation script that gets you up and running in no time.
Subscribe for weekly videos
Can’t wait until the undocumented features of wifi cards get hacked and can receive out of bounds. Atheros cards currently have about 1GHz of range by changing a few numbers in the kernel source code, but it would be nice to have more…
@dattaway2:
May you give some details on the Atheros hack? It might be useful for operating it on the amateur radio bands…
Probably just some code tweaks in the madwifi module code.
Here’s a link for info on going out of band on a few wifi chipsets.
http://www.qsl.net/kb9mwr/projects/wireless/modify.html
Wonder if it can be done using a TP-Link WR703N for a very low cost, very mobile SDR solution
Yes, that works. You need to use a smaller buffer size though, otherwise the device runs out of memory. ‘rtl_tcp -b 12′ seems to work quite well here.
You can find the OpenWRT Makefile here (also linked in the rtlsdr-wiki).
http://steve-m.de/projects/rtl-sdr/Makefile
A somewhat outdated, pre-built version of OpenWRT and rtl_tcp for the WR703N can be found here: http://steve-m.de/projects/rtl-sdr/rtl_tcp_openwrt.tar.xz
I followed the link from digifail to the pwnplug. That looks like an interesting device but the cheapest price is $195. Am I missing something?
the SDR stuff is interesting though….
Yea it is a bit expensive for what it is, maybe replace the ShivaPlug for a $50 craigslist laptop, nice setup though.
I already had the Pwn Plug from other work I was doing, I certainly wouldn’t suggest anyone go out and buy one of them unless you actually had a use for the pentest setup they have going.
You can just as easily get the SheevaPlug it’s based on, which go for ~$100.
The hardware is a good choice for this kind of thing, it draws a maximum of 7 watts and has no moving parts.
Oh well that makes sense, if you had it on hand already.
This is great! Wish it wasn’t so hard to learn gnuradio, Python, and everything that comes with writing SDR software.
I know a better (cheaper) way to do this. Just plug a small radio receiver into PC’s audio IN jack and stream that on ustream.
@electroalek that’s grossly oversimplified. Read up on SDR.
there’s no reason this couldn’t be done with one of the various new android/ARM dongles as well – I just picked up mk802 for USD73 shipped. when I get the free time I’d be happy to try, although I’m guessing someone will beat me to it…
(oh, and that was for the 1gb ram version. 512mb is a few bucks less than that. also? raspberry pi, if you can actually get your hands on one.)
Reblogged this on txwikinger's blog.
I’ve done this with a Pandaboard and ghpsdr3-alex, using QTradio and aHPSDR on my phone/tablet to connect (mostly because I had issues running anything pyWxwidget based on the board, segfaults ahoy!).
I didn’t realize that gnuradio could hit rtl_tcp though, I’d been trying to use the local interface blocks from osmocom. Might try using gqrx on another machine, and only the panda as a receiver.
It would drop the CPU usage on the pandaboard a lot, as the dspserver compiled with armhf+neon keeps both cores at ~75% when in use.
Using a sheevaplug for this is pretty brilliant. Keeps it out of the way, and plenty of power to run the rtlsdr stick.
I have also noticed missing IQ frames, good to hear I’m not alone, and now I know why and how to fix it.
Thanks, MS3FGX! Excellent write-up, hope to hear about more of your developments in this.
404 me all to hell. It worked the second time. (BIG Oopz!) **it happens.
