Nyan Fax Brings The Celebrity Kitty To Your Office
Internet blocked at your office and feel like you’re just not getting your fix of Nyan Cat? Don’t worry, you can now use the fax machine to get your fix. [Tom Scott] put together the project to our delight, which will work best if you can find one of those fax machines that uses the continuous roll of paper. But as you can see above, individual sheets will work too. The best part is that Nyan Fax is live for callers from the UK and internationally!
The hack is using something called ‘fax polling’. It allows the sender to set up an on-demand server where any caller will be sent a queue of documents. In this case [Tom] crafted a Nyan Cat document that never ends… you’ll need to disconnect the phone line or pull the pug to stop the printing. See for yourself in the clip after the break. If you’re interested in setting up your own it can be done with the mgetty and sendfax packages on a Linux box.
Just in case you’re keeping score, [Tom Scott] is one of the guys behind the Webcycle.
20 thoughts on “Nyan Fax Brings The Celebrity Kitty To Your Office
  1. Wonder if you could somehow transfer the nyan cat to a fax machine and do it to someone else.
    All my lines are voip now so barely work for fax at the best of time anyway.
  2. Man, if you could just go to a site and send it a number to send a fax to then that would be a perfect office prank to do after everyone has left for the day.
    But, better yet, it might be just as much fun to make the office have to pay international long distance charges too. :D
Leave a Reply to richmsCancel reply
