GPS Dog Collar Keeps Track Of Your Walks
[Becky Stern] came up with a way to make sure you and your dog are getting enough exercise. It’s a dog collar mounted GPS that measures how far you have walked. Just set your target distance and the progress bar in the middle of this flower will let you know when you reached it.
The most obvious piece of hardware is the OLED board which is sticking out like a sore thumb. But if you’d like to be a little more discreet you could forego the full-featured display for some carefully places LEDs to make up a circular progress bar. The GPS module itself fits well in the center of the flower, which [Becky] shows us how to make out of wire-edged ribbon. Hidden on the other side is an ATmega23u4 breakout board running the Arduino bootloader.
If you’re interested in sewables and textiles [Becky] uses a lot of basic techniques that are good to learn. Check it out in the clip after the break. She’s always shown a remarkable ability to develop projects which won’t scare away the villagers in the way our wire-sprouting breadboard hacks sometimes do.
9 thoughts on “GPS Dog Collar Keeps Track Of Your Walks
    1. Could be something to do with the precision required, because the distance travelled between updates is so small.
      She appears to be using Haversine which is supposed to give pretty good results if you only have low precision arithmetic available. The way she’s implemented it is not particularly optimized though.
Leave a Reply to JohnnyCancel reply
