Building A Coffee Roaster From Junk
[Rxdtxd] has tried his hand at roasting coffee beans in a frying pan. It works but he can only roast small batches at once. What he really needed was a large-scale roaster that would have no problem with a few pounds of the green beans all at once. He ended up building this large-scale coffee roaster out of junk parts.
The vessel which holds the beans is the drum from a top-loading washing machine. It was headed for the junk pile, but the fully-enclosed drum is perfect for this purpose. After acquiring it [Rxdtxd] set out welding a frame that would hold either side by the pivot points. He used a geared motor to automate the process. The output shaft on the gear box is meant to drive a chain, but he just welded some pieces onto the gear to use as a coupling.
In the picture above he’s giving the roaster a thorough testing with about ten pounds of beans. A portable gas stove placed below the rotating drum supplies the heat. After the beans have reached the desired darkness he pours them out into a large skillet to cool. Take a peek at the roasting action in the clip after the break.
10 thoughts on “Building A Coffee Roaster From Junk
  1. I like the simplicity and recyclign aspects of the build. Havign said that, I thought one of the main draws to roasting your own coffee was getting the freshest roast possible? Unless you’re opening a boutique or roasting for a large hackerspace it’s going to take quite some time to work through 5-10lbs of beans. By which time many of the volatile flavors you initially had will be gone. I see he uses glass candy jars but I doubt the efficacy of their seal over many months.
    Vacuum packed Aluminized/mylar bags with optional oxygen absorbers(if your a belt and suspenders kind of person, and for use after opening the initial seal) would greatly enhance storage life.
  2. The tub design looks like it came from a Staber washer, which oddly enough looks like the best application for their drum design, nice to know something good came out of it.
    make mine a dark junkyard roast, hold the rust! awesome!
  3. nice hack. i personally use a gas grill with a similar stainless steel drum on a heavily modified rotisserie mount. the grill helps to hold some of the heat, so maybe a cover for this setup would do the same…
Leave a Reply to CB4Cancel reply
