Writing on LEDs with a laser pointer
After [Ch00f] got his hands on an 8×8 LED display, he didn’t make a 64-pixel video game or VU meter. He made a laser doodler, allowing him to draw on this display with only a laser pointer.
Using LEDs as light sensors is nothing new; [Forrest Mims III] discovered that LEDs can also detect light way back in the late 60s. [Ch00f] played around with this concept before creating a circuit that uses an LED as both a light emitter and sensor that reacts to the ambient brightness.
[Ch00f]‘s laser doodler takes this phenomena and applies it to an Adafruit bicolor LED matrix. When a light shines on an individual pixel in the display, the ATMega48 senses the current and turns that pixel on. Since this these pixels have two colors, [Ch00f] used a latch circuit and a button to cycle between what color the ‘Mega writes to the display.
In the video after the break, [Ch00f] shows off his display by having the LEDs light up in response to a laser pointer. It may be a bit small, but we can see a lot of potential for something like this as a gigantic art installation.
Comments
  1. loathingkernel says:
    Very cool. And I think this hack can be used to even impress some chicks! Kudos dude.
  2. Robot says:
    Why not use different color laser to paint different color pixels ? I think there should be some sensitivity difference between different colored lights
  3. glamar says:
    So when will all LED screens become touch screen, by sensing no light where the finger is? … opps led screens only use LED for back light.
  4. Rob says:
    Love the creeper at the end.
    You know, I actually have a use for this project! Might play around with this.
  5. birdmun says:
    Rather than a button to select color, could you use a pulse modulated signal that the LED picks up to select the color?
  6. bzroom says:
    isn’t this a repost? the only addition being a button you hold down that changes color?
    http://cs.nyu.edu/~jhan/ledtouch/index.html
    https://sites.google.com/site/studioelectricsheep/pj/2dphotodiodearrayusing8x8dotledmatrix
  7. greg says:
    Does anyone else see the optical illusion? Where the dots appear in the black space on the grid? Stare at it for a while.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 98,146 other followers
