Writing On LEDs With A Laser Pointer
After [Ch00f] got his hands on an 8×8 LED display, he didn’t make a 64-pixel video game or VU meter. He made a laser doodler, allowing him to draw on this display with only a laser pointer.
Using LEDs as light sensors is nothing new; [Forrest Mims III] discovered that LEDs can also detect light way back in the late 60s. [Ch00f] played around with this concept before creating a circuit that uses an LED as both a light emitter and sensor that reacts to the ambient brightness.
[Ch00f]’s laser doodler takes this phenomena and applies it to an Adafruit bicolor LED matrix. When a light shines on an individual pixel in the display, the ATMega48 senses the current and turns that pixel on. Since this these pixels have two colors, [Ch00f] used a latch circuit and a button to cycle between what color the ‘Mega writes to the display.
In the video after the break, [Ch00f] shows off his display by having the LEDs light up in response to a laser pointer. It may be a bit small, but we can see a lot of potential for something like this as a gigantic art installation.
[youtube=http://www.youtube.com/watch?v=mi5vIlPz_J4&w=470]
13 thoughts on “Writing On LEDs With A Laser Pointer
    1. I actually tried doing this with a red laser. The problem is that green LEDs will pick up very little from a red laser, and I can’t use the red LEDs as sensors without another 8 I/O ports on the microcontroller.
Leave a Reply to RobotCancel reply
