Not quite building a Raspi Arduino bridge
A few months ago, [Omer] sent in a Raspberry Pi to Arduino bridge he’s been working on called Ponte. Now that he’s gotten a few assembled, he can actually test out his ideas for combining the powerful Raspi with the ubiquitous Arduino.
Ponte revision 0 used a pair of 12-bit analog to digital converters, but during the soldering and debugging phase of development [Omer] discovered a few things were wrong with his original design. The FETs on the fabricated boards had the drain and source pins mixed up, but that problem was easily solved with a bit of board surgery.
The worst problem was the mechanical design of Ponte rev. 0 – the power jack on the Ponte is directly above the Raspi’s USB port, meaning it’s impossible to plug the Ponte into the Pi.
[Omer] is working on these problems and should have  the revised boards completed shortly. A few people have asked where they can get a Ponte, but right now there are no plans to assemble and ship boards. That may change, but for now if might be worth bugging [Omer] to put his new and improved Ponte (with an 8-port I2C port expander!) up on SeeedStudio
Comments
  1. Drake says:
    Right angle header?
  2. fonz says:
  3. Velum9 says:
    I can’t seem to find it over on seed studio :-(
  4. Anthony Mills says:
    I cant seem to find it on Seed Studio :-(
  5. Jarel says:
    I hate Seeed Studio! :-)
  6. behzat_c says:
    Let’s bug [Omer] from his website http://omer.me to be able to find this board on Seeedstudio :)
    Or you might try to bug Seeedstudio to get in contact with Omer as well. :)
  7. cgimark says:
    This is a good example of why you should always build a circuit on protoboard or stripboard or something similar to work out the problems before doing a fabricated pcb, unless you have money to throw away.
  8. ESP says:
    Honored for the mentioning, Seeed will bug [Omer] :)
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
