Birth of an Arduino
Hey look, an Arduino without its clothes on. This one’s just started its journey to becoming the ubiquitous prototyping tool. The image is from [Bunnie’s] recent tour of the fab house where Arduino boards are made.
As it says on every true Arduino board, they’re made in Italy. [Bunnie’s] trip to the factory happened inĀ Scarmagno, on the outskirts of Torino. The process starts with large sheets of FR4Ā copper clad material, usually about 1 by 1.5 meters in size. The first task is to send the sheets through a CNC drill. With all of the holes done it’s time for some etch resist; the image above is just after the resist has been applied. A robotic system takes over from here, running the panels through the chemicals which first etch away the copper, then remove the resist and plate the remaining traces. From there it’s off to another machine for solder mask and silk screen.
There are videos of each step available. But our favorite piece is the image at the end that shows a pallet with stacks of completed PCB panels which are headed off to be populated with components.
[via Reddit]
5 thoughts on “Birth of an Arduino
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
