Extending the range of the AR Drone, 2 ways.
As I mentioned earlier, we’ve got an AR Drone to play with. One of the common mods that popped up on the internet were ways of extending the range on the AR Drone. It normally uses a local Wi-Fi connection to your phone or tablet for control and video signals. Many found this quite restrictive and have gone pretty far in extending that range.
The first and easiest was just to set up a higher power Wi-Fi Bridge where you’ll be flying. The Drone only has about 15db of wi-fi magic in it, so anything stronger than that is an improvement. There were too many variations on this to delve into the details, but as you see, there’s not much too it.
The second method is to completely replace the Wi-Fi control system with a nice R/C controller. This will greatly increase your range as well as give you extra channels for triggering different attachments (usually lights).  I’ve seen two main methods used. One is called “MacGuyver mod”. This one is a plug and play kit that doesn’t seem to have much info along with it.
The other is called “MiruMod” and the creator has shared all the information they can.  You can find a parts breakdown as well as schematics, wiring diagrams, instructions, and software. [Miru] uses an Arduino Pro Mini or an Arduino Nano as a go-between from the receiver to the serial port on the AR Drone. You can see in the wiring diagram below that it is a fairly simple install, and all [miru] asks for is that maybe you donate some beer money if you appreciate his mod.
50 thoughts on “Extending the range of the AR Drone, 2 ways.
  1. My ford van is setup with a 75 foot collapsible mast for ham radio operations during emergencies (I’m in ARES). One of the radios at the top is a ubiqiti 1000mw access point on a 20db sector antenna. (Before you cry foul, as a HAM, I follow the rules, I keep it tuned to within the ERP limits.) My brother has one of those little AR drones, and it exhausts its power supply before it can fly out of range of the van.
    1. I don’t know much about drones, but I use a 2W ALFA usb attachment for wifi hacking. I am able to mod the driver to bypass the regulatory limitations. I am aware that this is not legal, I am curious though if it theoretically could be done with a drone, for educational purposes only, etc. Also, I se that some drones have 4g for video transmission, but couldn’t a drone also have signals for flying/range/control on a 4g connection much like I can remotely control my android?
    1. Then put another wifi extender on the second to control the first, immediately stop thinking at all, and you have a perpetual motion device for youtube! The conspirators won’t be able to hide your world-changing proof from the world!! :D
      Sorry I recently waded through 10-15 perpetual motion videos on youtube. *Heavy sigh*
    1. The launch coordinates appears to be at
      47°34’39.49″N, 8°54’42.65″E and the landing location was about 1 km to the south.
      The part of Lake Constance visible in the video is about 8 km distant. A rough estimate places the drone and about 70 m above the ground
  2. I didn’t know the AR Drone had “Rouge mode” LOL.
    BTW, Ain’t that suppossed to land automatically or something when the signal is lost? :O major fail right there.
    1. Yeah, it doesn’t automatically land. That’s why I sold mine, I couldn’t safely go outside without it suddenly taking off at a massive acceleration directly upwards and then wandering around for the 3-4 minutes it took for the battery to die out.
  3. great for wardriving/flying
    with some AI at the backbone , this could be a great surveillance drone or guard. to watch your house when your gone.
    take out the trash…
    water the plants…
    and so on.
      1. You obviously don’t know much about R/C helicopters….
        The motors are only designed to last around 15 minutes at a time. Even if you put heatsinks on them, they will overheat and catastrophically fail if you go over the time limit.
      2. I’ve only flown multirotors and never flown RC helicopters, but I can tell you that the motors and ESCs do _not_ continue to heat up in a prolonged flight.
        The same may not be true in a helicopter where the motor RPM is held constant (and high, I presume), but for my tricopter, hover happens at around 30% throttle. I wouldn’t be surprised if other multirotors perform similarly.
    1. I think what tends to overheat is the battery and not the motors. The battery has to source a fairly hefty current for its size and that causes it to warm up. the increase in temperature raises the internal resistance, limiting the overall power output.
      Most RC rotor-craft that I’ve seen using LiPo batteries recommend short cool down period between flight and charging and charging and flight.
  4. Both these mods look to be the same thing. The plug and play kit looks loke the MiruMod pre assembled and offered with 2 different reciever options. you can see the arduino poking out at one end.
      1. It’s powered by 10C 3S 1000mAh LiPos, that means the drone can draw up to 1A*10*11,1V = 111W from a 100g battery pack. I don’t think any solar panel would meet those specs (or will in the foreseeable future). There are alternative lipos available up to 2500mAh but hey are much heavier (I have a -not yet tried- 180g 2300mAh one) and bulkier.
  5. Great footage, but experiments on extending our range without putting an auto landing function on the vehicle for when it has lost signal and can determine it isn’t getting it back? Glad it’s a light weight vehicle….
  6. If i use the AR Drone 2.0 with the PC software that is out now and then i buy and installe a WIFI Booster on the PC i control the Drone from.. won’t that easly extend the fly range of the Drone? please respond =)
    Best Regards
    1. LOL…this is almost where the pursuit of extending range, began! There was a YT video about a year ago, which was showing a 3G dongle using the USB port on the AR Drone 2.0; but I believe the video’s been disputed as being fake….but since we have some ‘real’ solutions now (that don’t involve fighting ones way into the drone hardware/firmware); I’d expect a 3G/4G, solution was achievable, be it with a few extra grams?
      Has anyone looked into adding some kind of lightweight dangling, or top mounted antenna extension, to the drone itself (or does this make the device exceed regulatory set limits for an airborne transmission from a device of this classification?)
      1. I know, I know – but any progress on that?
        and in fact there was a (as usual “semi-believeable”) official parrot video (with alcatel lucent) claiming to have a prototype on 4G/LTE
        But any progress? any out-of-the-box mod for that?
        I tried to tape my old adroid-phone on the drone which I used to control it – so the drone could never get out of wifi-coverage… ;-) then I tried to remote-control the android with an app called webkey – but unfortunately did not really work stable enough to risk an extended flight…
  7. Old thread… but. Why could you use the arduino and just strap a wifi hotspot to the drone. Then you could ssh into the arduino and control the drone from anywhere.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
