The $100 Tri-copter
We’ve seen lots of budget tri-copters, but $100 seems like a heck of a deal to us! Watching this video, you can see this home made tri-copter is incredibly agile and seems to handle quite well. Whats amazing is that [hallstudio] claims that it cost roughly $100. That price is really good compared to even the cheapest multi copters out there.
Much of the manufacturing cost associated with this kind of thing has been removed as the body is just cheap wood from the local hardware store. He even did an admittedly sloppy rig for his tail rotor, not that it looks like it has hurt his performance.  One cool feature is the fact that you can fold the front arms backward, allowing for the tri-copter to be shoved into a bag for easy transportation.
You can find a complete parts list on his video, but it looks like maybe his cost doesn’t figure in the cost of the radio controller. There are no build instructions, but a quick google search leads us to the rcexplorer tricopter which seems to be the template he used. There are full build details there.
[via Hackedgadgets]
26 thoughts on “The $100 Tri-copter
  1. Nice video… cool build…
    I can see where a 3-D printer could build the body parts, maybe make it more streamlined, and maybe stronger.
    How involved is it to “balance” the blades as he mentioned?
    1. 4 channel is minimum as with standard aeroplane. Quads fly like a cross between a plane and a heli.
      My setup is something like this:
      Channel 1 Throttle Up – Down (Collective)
      Channel 2 Pitch Tip forward- backward
      Channel 3 Rudder (Yaw) Rotate around Z axis
      Channel 4 Aileron Tip left – Right
      Loads of info on the web to build and fly quads. Do to low cost, rugidness and autolevel capabilities they are much easy to get started with than 3D flybarless heli’s.
      1. Never played with radios… But with the prices of processors, why anything would need more than one digital channel?
        Price delta from 2 to 8 channels is absurd in those controllers.
    2. Hey,
      No, this is 4 channel. Aileron (roll), Elevator (pitch), Throttle, and Rudder (yaw).
      If you use a board with multiple flight modes (like any that use auto-level) it would require an additional channel making it 5.
    3. The $100 price does not include the remote (knows in the RC world as a transmitter). That is generally another $100+ unless you use a non-computerized remote. A non-computerized remote makes it harder to tune the controls to be less sensitive (known as Dual Rates and Expo). This is simplified, but there is lots of info that this article does not explain.
    4. Parts/price list for the cheapest build from the parts he listed:
      Motors: 2830-8 $18.99 each
      $43.96 + shipping for 4 motors
      ESCs: HK-SS20A-HW $7.80 each
      $31.20 + shipping for 4
      Flight Controller: HobbyKing Multi-Rotor Control Board V2.1 $14.99 plus shipping
      USBasp AVR Programmer $4.95 plus shipping
      10CM Male to Male Servo Leads (JR) (10pcs/set)
      $4.75 plus shipping
      14AWG (1mtr) RED wire $1.39 plus shipping per meter
      14AWG (1mtr) BLACK wire $1.39 plus shipping per meter
      Low Voltage Alarm $1.92 plus shipping
      Wood for the frame $???
      Screws/bolts for frame $???
      Glue for frame $???
      Minimum price plus shipping plus frame materials is: $104.55
      This does not include a battery.
      This does not include frame materials.
      This does not include a transmitter (remote) and receiver.
      1. *Your math confuses the heck outta me… Firstly, you say 4 motors, 4 ESCs (THIS IS A TRICOPTER!)
        Also, for the motors you say:
        18.99*4 = 75.96….. not 43.96
      2. @Steve, you are correct. Sorry, I have been building quadcopters for the last year, I just automatically think 4 motors.
        Because its a tri-copter, you will also need a servo.
        The motor cost, I used the total provided by the RCTimer shopping cart and didn’t think to check it. The motors are on sale. $18.99 is regualr price.
        Sorry about that.
        Here is the fixed price list:
        Motors: 2830-8 $10.99 each
        $32.97 + shipping for 3 motors
        $23.40 + shipping for 3
        $4.75 plus shipping
        Glue for frame $???
        Servo $????
        Minimum price plus shipping plus frame materials and servo is: $85.76
        This does not include the servo got the rear motor.
        This does not include propellers.
  2. Why do I get the feeling that this isn’t the first heli this guy has built and it therefore seems much more straight forward than it actually is? Are these things really that forgiving (thinking about how he drilled holes crooked and so on)? Or, is it his experience flying the things that lets him compensate?
    1. He is clearly a good pilot, but a wonky copter will be no harder to fly than a well-built one.
      They are that forgiving because the control board does all the work of keeping the copter stable. It runs simple PID (usually PI, but P works too) control loops, and doesn’t care if the copter is a bit asymmetrical or heavier on one side.
      These things will impact performance to a degree, but not basic airworthiness and stability.
    1. i wonder if a quad with 2 pivoting would prove interesting. I also saw a quad with collective pitch on the rotors a while back. This let it fly upside down and removed the need for speed controllers.
  3. I went to the site , and here is the cost details
    Quantity Stock Product description Price Weight
    OK DT750 – hexTronik DT750 Brushless Outrunner 750k.. $34.80 237
    OK TR_P18A – TURNIGY Plush 18amp Speed Controller $35.70 102
    OK BMS-385DMAX – BMS-385DMAX Digital Servo (Metal Gear) 4.. $61.44 114
    OK T2200.3S.25 – Turnigy 2200mAh 3S 25C Lipo Pack $17.98 454
    OK GWS-prop-RD-1147 – GWS EP Propeller (RD-1147 279x119mm) (6p.. $5.76 93
    TOTAL: $155.68 1000g
    It does not include the Receiver and TX.. it would around $190 total for everything he menetioned in his video.
Leave a Reply to qwertyCancel reply
