This home automation hardware turns on and off the lights based on room occupancy. The hack is an extension of an earlier version that was only a proof of concept. [RPisces] took the idea and made it into reality by mounting the sensor hardware in a doorway.
He prototyped the device using the MSP430 launchpad. It monitors a pair of IR distance sensors which record a change when something passes between them and the opposite side of the hallway. This is a good sensor choice as it only requires hardware on one side of the passageway. Because two of them are used, it’s quite simple to figure out if a person is entering or leaving the room based on which is tripped first.
In this case [RPisces] drives a relay to switch a lamp on and off. But it could be used for just about anything. We’d enjoy seeing it trigger an audio system like the one [Quinn's] installing in every room.
Subscribe for weekly videos
Yes, ditch the lamp. Two is a crowd three’s a party. Cue the music.
This won’t work very well when two persons are simultaneously passing the “Sensing Area”…
The only solution in my eyes is to make the doorway a one-person hatch. With separate hatch for beverages, naturally.
Install a turnstile in every doorway!
Find a way of hacking up this ‘magic carpet’
http://www.bbc.co.uk/news/science-environment-19479365
Wasn’t there a project featured on HaD that uses multiple kinect units to map a room with a great degree of accuracy? Some clever person can extend that system to detect whether or not there’s anybody in the room. Also, one can implement some logic to recognise gestures and possibly even identify the people in the room. For instance, if it detects two people and one makes a lot of agitated gestures indicating anger, then it can pacify him with a tranquilliser dart or something. (c:
Good job sir!
I have thought of this exact same device, and made a prototype of it earlier this year but have not extended it to mains yet.
My version, to check for direction, needed sensor A then sensor B to activate in the right order, followed by both being on, followed by A turning off then B turning off. The opposite was needed for the other direction. I found that doing this removed errors of someone popping in and out, or standing in the doorway.
I also had the counter bottom out at 0 to avoid longer errors. It is useful to have a button to reset the count if it gets messed up.
Another feature that I wanted to add that is quite nice, is a manual overide that turns off the light until the count reaches zero. For example, if you want to go to bed, you can set it to sleep, then if anyone else walks in it stays off. However once everyone has left, it resets to normal operation.
Professional systems try to count people in the room and the all have failure points. the ony solution is the triple technology occupancy sensors. they use IR, FLIR, and Ultrasonics to get a 90% accuracy. nothing will deliver 100% accurate.
You can get pretty close by hiring a person to stand at the switch and flip it. Should get very close to 100%, except for when they fall asleep.
I did same thing a couple of years back for my graduation thesis. It is not in English though.
It was done as a part of a device network I was working on (and using it). But after graduation the life kicked in and I’m making version 2.0 ever since :).
Arghhh… screwed up post format – can I edit it? Here is presentation video link on youtube:
http://www.youtube.com/watch?v=sATcqVFGSjE#t=12m15s
how does this work if there is more than one person entering/leaving the room?
person one enters, light turns on, person two and three enter, light remains on. person three leaves, light turns off, and person one and two are left in the dark? :(
‘home automation’ might be a stretch…
It counts them in 1(on)..2..3 and counts them back out 3..2..1(off), the problem comes if the people are huddled together as they enter and the system thinks only 1 or 2 entered, then you get the problem you describe.
all of my rooms have a small rectangular plastic plate with a small rectangular plastic post sticking out that I TOUCH if I want the light ON or OFF
Nice. I like the use of dual IR sensors for intelligent sensing. I just wonder how practical the control is long term when set to specific assumptions.
Also, this project is using the sensor for 1 relay activation, when some logic would do instead of a micro. Funny how micro’s are taking the logic out of design.
Logic gates / counters could be used for multiple outputs and LEDs as well….just sayin….
you might be able to use only one sensor, placing it a bit diagonal to the hallway. the software will detect the direction of movement by the person getting closer or farther from the sensor.
We already have a universal program almost anything’ interface. Its called the parallel port.
