Pulse jet tea kettle
[Colin Furze] is just showing off in this picture. His pulse jet tea kettle is built well enough to get by without help from a blow torch, but who can blame his showmanship? In fact, once it’s running there’s no flame to be seen. That’s because the combustion happens at an earlier stage of that pipe, heating a segment that is submerged in water so that you may have your tea in no time.
Once this thing is tuned up it roars like a robotic lion. [Colin] yells his commentary at the camera, but it is picked up as nothing more than a blip of distortion. Pressurized propane and air both feed into the jet. they’re regulated by the two knobs on the base of the unit (that enclosure is actually just a pie tin). There is also a 9V battery-powered igniter built into the base. You can see how the unit was built in the video after the break.
[Thanks Manicphase]
Comments
  1. uC says:
    This made my day.
    I’ll have a cup of tea, hold the eyebrows please.
  2. crenn says:
    That guy is way to happy… It’s an awesome project and have to stop every so often to laugh.
  3. jwweather4 says:
    Subscribed! I had tears in my eyes, this was beautiful.
  4. bigdeal says:
    This guy is hilarious! A few childish jokes that turned into great inventions and hacks, and the rest of the videos involve destruction, fire, crashes and laughs! He actually got in a bit of trouble for his flame-throwing scooter, check that one out on his channel :)
  5. bubonicfred says:
    For someone who is British he seems woefully bad at making tea.
  6. fifthrider says:
    God; he sounds exactly like Wheatley. With the same propensity for bad ideas.
  7. flink says:
    Does anyone have some practical experience with pulse jet furnaces/water heaters? I am curious if it would be possible to use a pulse jet to power a DIY foundry kiln to do some aluminum work.
    • Dax says:
      I’ve heard that the Germans have experimented with using them for central heating back in the 30’s, but they used the exhaust of the pulsejet to pump hot air through pipes.
      • flink says:
        There is at least one company in the US using them for heating and hot water. The Jettle demo showed the exact outcome I was looking for: A bright orange iron piece. That’s the kind of heat I want for melting aluminum.
    • hospadar says:
      Probably it wouldn’t really be any better than a regular burner. The only think the pulse jet really buys you over a simple burner is the thrust, and if you’re not putting that to work, you’d just be loosing energy.
      If all you’re trying to do is heat up a little box, it’s probably overkill. If anything, the waste thrust from the pulse jet would probably steal energy from your foundry (the energy for the thrust has to come from somewhere)
      Furthermore, a burner is a lot easier/cheaper to make than a pulse jet which is more picky about sizes and dimensions (I gather).
      My impression is that foundry efficiency is mostly about insulation and thermal mass. Better insulated and less thermal mass == better foundry. Unless you’re blowing uncombusted fuel out the exhaust of your foundry, you’re going to be getting just about all the heat you can.
      If you had an operation like home heat or water, where you could use the mechanical energy of the thrust (through a turbine perhaps) to do some other work you needed to do (like pumping hot air/water) or to generate electricity in a combined heat/power setup – there I think you might really have one.
      That said, I’m no jet expert, maybe the compression in the pulse jet helps you squeeze extra useful joules of heat out of the fuel?
  8. hospadar says:
    Great presentation! I wish more project videos were like that.
  9. buzzles says:
    Two things:
    1) Colin has good choice in china (technically stoneware). That stuff was Denby. It’s good.
    2) He brewed the tea with milk already in the mug! The muppet! Horrible way of making tea. Milk always goes in last.
  10. Hirudinea says:
    He has to detach the fuel supply to pour the water, bad design, what we need here is a pulse jet samovar.
    http://en.wikipedia.org/wiki/Samovar
  11. Erin says:
    I found some poetic humor in a Brit using a pulse jet, probably most famously used on the V-1, to make tea. :)
  12. n0lkk says:
    All that talk about manly, but it looks like he had a bit of tea with his milk & sugar ;) My coffee is black, my ice tea without sugar.
    • I care says:
      I never did quite understand why black coffee is considered manly. I prefer mine with milk & sugar.
      Though I am known to drink four shots of espresso, straight. With cream in the summer.
      So who cares.
  13. flower tea says:
    What is jet tea? I am really curious
  14. flower tea says:
    I am really curious how it works, what kind of tea is it?
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,577 other followers
