In the quest to add a digital readout to his mill, [Yuriy] has done a lot of homework. He’s sourced a trio of very capable scales, researched what kind of hardware his DRO should be based on, and even built a very cool display using seven-segment LEDs. After nearly a year of work, [Yuriy] finally hit upon something that works well: an Arduino and an Android tablet, perfectly matched for one of the prettiest machine shop displays we’ve ever seen.
[Yuriy] based his build off a trio of digital scales he bought from Grizzly. These scales bolt on to the frame of his mill and send data to their own display. An Arduino was used to pull the data off these scales and sent via Bluetooth to a Nexus 7 Android tablet.
Considering a DRO solely based on an Arduino and a character LCD would look a little chintzy – and the fact Arduinos can’t do floating point arithmetic – we’re really impressed with [Yuriy]‘s very elegant solution.
Thanks [Lee] for sending this one in.
Subscribe for weekly videos
Arduino *can* do floating point math.
Slowly.
came here to say the same thing. I think they could’ve worded that better.
Re: floating point math.
If one were to read the write up on his site, one would see that the floating point math is done on the android tablet.
Why, yes! Yes, I *did* read the original article. Nowhere does it say that Arduino can not do floating point math.
Indeed the floating point stuff *is* done on the tablet, but that’s incidental.
Once again HaD editors fail at reading comprehension.
Similar idea using old DOS laptops and cheap standard digital calipers can be found here.
http://www.yadro.de/
I did a bunch of work to make adapters from Cen-Tech (harbor freights brand) and Quadrature encoders to the Yadro hardware. Also have some Caliper to serial code available out there.
http://www.wire2wire.org/milling/cen-tech.html
http://www.wire2wire.org/milling/quadrature.html
Wish I had seen these calipers before I started would have been much easier to mount :)
That looks fantastic.
Using a high resolution display to show segments -why? Showing the inactive segments – why? Using light blue in slightly darker blue to further reduce contrast – why?
I’d use a fixed width font with high contrast or different colors for the axes. Check out dark schemes for syntax highlighting or just the HaD color scheme.
I’m guessing just because it was his UI design and he liked it that way. It may have slightly less contrast and is mimicking a far less capable technology, but I must admit I like it too.
Inquiry,
The color scheme is actually white on black. The picture was white-balanced for incandescent light, so the screen came out blue. (look at the screenshot in the latest post).
As far as the other questions: I was just playing with the UI and it made sense to mimic the “traditional” look. It might change in the final version…
Thank you
Yuriy
I am not sure if i missed this in the blog, but is the android app available now or is it still in development.
Very cool design and concept. I would love to see the Android code and what protocol you used in the N7. The limited reading I have made on it shows limited BT protocol alternatives, but I am a newbie… Great project, congrats!!!!
Give it an LCARS skin and I’m sold!
Better get a hefty screen protector for that tablet! I’d hate for the screen to get scratched up from metal chips on your greasy hands…
Genius using the Android tablet! I have seen PC clones used similarly for XY interferometry measurement on very expensive machinery.
Google needs to create an industrial division, seriously.
Consider how PC clones are pressed into use for industrial and commercial tasks because they are so cheap. One factory I worked in had every QC gauge connected to a PC clone, in turn all connected via Ethernet to a server (also a PC clone). A bar-code reader and data logging unit used to cost $4k, so people started using serial port readers and PC-like laptops that together cost $1.5k. Android tablets can be used for all of this, cheaper still.
Android aint good for industrial applications, or at least not yet… PC clones are useful because everyone are familiar with the architecture and software. Android has great graphics which the factories dun really fancy so its not worth having to redesign a new system.
As of now, there are already a few scada systems that can be run off android but it doesnt seems to be taking up
Android is not realtime.
But works great as an UI.
Considering cheapest tablets can be had for $50 (probably $70 with decent IPS screen instead of crusty picture frame 800×480 TN cant-see-shit-at-an-angle kind)
I remember the invasion of Windows95 on the plant floor replacing PLC’s and assembly language IBM clones. Judging by the scrap and downtime, it wasn’t read either. But it happened. Whatever the latest engineer is familiar with, that technology will happen.
“Android … for industrial applications … at least not yet.” Give it three years.
Purchase decision makers felt comfortable with PCs (even Ludites who did not use them but wanted a “justifiable” decision). The same is happening now, even more so, for tablets. People who will not touch a PC or Mac trust Kindles, iPads, etc.
The factory I mentioned with a PC clone for each QC gauge had some stations with 3 and 4 side-by-side PCs (and keyboards and monitors), but management was more comfortable with that than using “non-standard” PCs with more than 2 serial ports or switch boxes to select amongst what was in use.
PCs and, I predict, tablets are like duct-tape, cheap low-tech that works for almost everything.
On a side effect, not many supplies want to provide open-sourced solutions, (its not like they can sell a system every other day) thus they definitely wants to lock their customers (apple?).
Now everyone is just waiting for that “market spoiling” disruptive product and all hell will break loose.
@ Brian Benchoff
You should go and offer it to the guys that do CNC machines. I know of one who would buy few CNC readouts from you http://www.pa-international.com/products/cnc-machining-china
Surprising how guys never actually market such a great ideas.
I have see a guy trying to do it with his Iphone4S. Spent months with out much luck. Well done, great project!
I know this is a fairly old article, but for those of you asking for the source code for the project, it’s now posted on BitBucket: https://bitbucket.org/ycroosh/android-dro. Still work in progress, but should give an idea what it’s doing.
