Turning a plush Dalek into a WiFi enabled robot
You can now “EX-TER-MIN-ATE!” with one finger since this plush Dalek from Doctor Who has been turned into a wireless robot. The build started out with the toy whose only trick was to spout quotes from the popular science fiction television series. [Madox] took it apart to see how it worked, then added some of his own goodies to make it better.
We just looked in on a project from this guy on Tuesday. It was a light painting wand that used the TP-Link TL-WR703N wireless router. This uses the same tiny hardware as the controller. Since it’s a WiFi router it’s quite simple to serve up a control interface on any browser. To make it all work [Madox] designed and printed a new base plate. This provides brackets on which the two servo motors can  be mounted. It also gives him a place to anchor the driver board and the router itself. The original voice hardware is still there, driven by a connection to the router hardware. See the final product in the clip after the jump.
Comments
  1. Chirpinchuckthehumanduck says:
    So funny. :)
  2. Amatol says:
    You think this is harmless fun ?
    This is how it STARTS !
    NEVER let Daleks have any type of electronics !
  3. Hirudinea says:
    Oh he’s so cute I say we let him take over the universe! How hard would it be to put a custom voice module in this set up, so he could say “Oh F**K stairs!” for instance?
  4. M4rc3lv says:
    I wasn’t aware of the fact that pluche Dalek’s exist. Now I want want too.
  5. Chris C. says:
    Strange that a Dalek would be cuter and less menacing than a Furby.
  6. agtrier says:
    What about stairs?
  7. be it known says:
    There is one thing you are better at than the Daleks.
    DIEING!!
    EXTERMINATE!! EXTERMINATE!!
  8. corvair says:
    Can this method be coupled with a USB hub for use with other tech such as as webcams, etc? Or does the script need complete access to the sole USB slot?
  9. Madox says:
    Hi Corvair,
    There should be no problem, I actually bought a small slim webcam to see if I can squeeze into the stalk of the Dalek.
  10. pcf11 says:
    Nothing says love like a rampaging plunger wielding robot!
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
