Turning A Plush Dalek Into A WiFi Enabled Robot
You can now “EX-TER-MIN-ATE!” with one finger since this plush Dalek from Doctor Who has been turned into a wireless robot. The build started out with the toy whose only trick was to spout quotes from the popular science fiction television series. [Madox] took it apart to see how it worked, then added some of his own goodies to make it better.
We just looked in on a project from this guy on Tuesday. It was a light painting wand that used the TP-Link TL-WR703N wireless router. This uses the same tiny hardware as the controller. Since it’s a WiFi router it’s quite simple to serve up a control interface on any browser. To make it all work [Madox] designed and printed a new base plate. This provides brackets on which the two servo motors can  be mounted. It also gives him a place to anchor the driver board and the router itself. The original voice hardware is still there, driven by a connection to the router hardware. See the final product in the clip after the jump.
11 thoughts on “Turning A Plush Dalek Into A WiFi Enabled Robot
  1. Oh he’s so cute I say we let him take over the universe! How hard would it be to put a custom voice module in this set up, so he could say “Oh F**K stairs!” for instance?
Leave a Reply to MadoxCancel reply
