[Derek] likes to get a little bit of drivers-eye footage when racing his motorcycle, but there’s an inherent problem with mounting a camera to a moving and tilting platform. When he leans into turns, the camera can’t keep the horizon level. Cinematography and electronics go well together. so [Derek] built a horizon-stabilized camera mount for motorcycle videography.
The build was inspired by footage shot from [Valentino Rossi's bike in 2010. Of course the professional model costs a small fortune, but [Derek] managed to make his own out of 3D printed parts and a hobby servo.
Based on the Contour Roam camera, [Derek] had a pair of gears printed at Shapeways to fit over the camera and attach to a servo. The electronics are an ATMega32 with a L3G4200D gyroscope. When the ‘micro detects a change in the gyroscope it rotates the servo in the opposite direction, keeping the horizon in the video level.
It’s a very cool build, and judging from the action videos after the break, makes for awesome track footage.
Subscribe for weekly videos
Not bad but I would have just put the camera in a liquid.
Aside from practical issses, that wouldn’t work because of the centrifugal (yes, this one applies here) power.
*issues
you would need a pendolum system otherwise it would be stuck to the bottom and the effect would be null., besides the liquid could could introduce delay. better use a pendolum system without liquid, just air. I think the system of the cheap inclinometers that we find in TT trucs would be the easiest/cheapest way to get a working mechanism.
inclinometers would fail because of the lateral g-force the system is undergoing. They only work on crawler trucks because they are…crawling.
RC helicopter/quadcopter people have access to some cool and reasonably priced motorized stabilized camera gimbals that are compatible with even big DSLRs.
The DJI Zenmuse gimbal which is shown in the video you linked is about $3500, but I guess ‘reasonable’ is all relative to the situation. It is a very nice gimbal though and super smooth.
sure yes, but that’s not the only gimbal that’s available out there.
I guess the real point is, where on earth are you going to mount a DSLR-sized 2-axis gimbal on a motorcycle? This is definitely the correct and cheapest solution to the problem.
the gyroscope in a chip is not influenced by the centrifugal force?
I wouldn’t have thought that!
Yes you are right. Only a accelerometer is measuring the acceleration. This is why gyros are used in Multicopter projects
Really impressive that! Nice simple and cheap solution!
A gyro only will drift over time, right? So how does he compensate that?
Based on the smoothness of the camera, it appears he is already applying some filtering to the gyro signal. Filtering out sensor bias wouldn’t be that difficult if he averaged at a rate longer than a typical turn length.
The L3G4200 as well as the L3GD20 is a very accurate . You don’t have smoth the output much.
But the drift is always there, no matter if you angle changes or not. So if no accelerometer is used to compensate the drift you’ll get an angle offset of about a couple of degrees after a couple of minutes.
The gyros do drift. In addition, errors accumulate due to vibration, climbs and descents, etc. My solution was to monitor not just the roll angle, but also the roll and yaw *rates*. When the roll and yaw rates are both zero this indicates the bike is level (ie. on a straightaway) and the gyro/camera can be re-centered. In this way the gyrocam is self correcting. Of course the devil is in the details (signal smoothing, timing constants, etc.)
THis issue is common in UAVs, it’s called AHRS algorithms, look up DCM and Quarternion methods
Why not use the gyro he already has. his head. When riding a motorcycle you tilt your head. Look at the guys that use the helmet mounts, they already have this PLUS get free vibration dampening from the neck.
It can be difficult to mount your head on the rear of the motorcycle. Still, that is the simplest hack.
Yeah, but then we only get a picture of his butt, which I could have done without.
It is a nice build though. I was concerned about jitter from the servo, but it seemed to correct wonderfully. I think this is much better than the helmet mounted cams. I think they vibrate even more.
Your head is not always in line with the motorcycle (in multiple axes) and also gets buffeted by the wind. Mounted to the bike gets a stable platform and gets across how much the bike is leaned over.
Attach a camera to the head of the rider? Nah, birds can do it better, because they’ve got a longer, more flexible neck. Strap a camera to the head of a chicken and then tape the chicken to the bike. Problem solved.
Yeah, like this: http://www.youtube.com/watch?v=UytSNlHw8J8
Helmet mounts are terrible. You have to deal with buffeting, the head bouncing up and down on some rougher tracks alone can cause motion sickness in some viewers, and you won’t get anywhere near as smooth and accurate leveling.
Plus then you have to deal with a couple pounds of camera gear strapped to your head when you are already fighting the weight of your helmet and the various forces in play to begin with.
Very nice results!
This is very impressive, have you thought of mounting a 3D camera?
Awesome build, awesome footage.
Kudos.
is possible to have the atmega code for this project?
I’ve added a “parts and software” section at the bottom of the web page.
Man, all in all, this is a really good solution, and really well executed. Perhaps more importantly, REALLY good looking results! Feels like I’m riding the bike :).
Bravo!
nicely done!
I’d use a weighted and damped pendulum with a simple linkage above the pivot point to tilt the camera the opposite direction.
Lean bike left, force pushes pendulum right, link tilts camera right.
Want to get fancier to make it more stable, use solid state gyro and accelerometer to control a brake so the camera isn’t allowed to move past level point. No motor required, just a short throw solenoid with a felt pad to press against a surface.
Just to set the record straight, solutions based on flotation, pendulums, levers, etc. don’t work in rotating reference frames.
Derek, very nice build! Do you plan to offer kits or making this available in any way?
I’m not going to produce any kits, but the last link on the website points to a fairly detailed parts list, pc board design files, stl files for the gears, cutting sheet for the enclosure, and source code.
This is definitely not a “buy some parts and bolt them together” type of project. It requires some embedded programming skills, small parts fabrication / assembly, etc. But I put the info there for anyone who wants try it, or is just curious about how it works.
I want to make something similar, I was hoping to use the inbuilt gyro in an android pad, to trim 2 axis on a steadicam, but then I found this thing and thought it might be easier to get working http://www.dunehaven.com/gs1.htm
Hi all,
Is there any way to access to the link given in the article http://checksix.ctdracing.co.cc/gyrocam/ ?
It appears to be broken.
It’s a shame, I had the project page opened in a tab of my browser during months, I just bought my Contour Roam to build the same (I have embedded electronics skills), and now the project is offline… :/
Thank you
webpage is now at:
http://revenanteagle.org/checksix/gyrocam
Great, thanks!
