Lucky Cat Hit Counter
[Jan] was looking for a way to monitor web site hits while sitting on the couch. This lead to the Lucky Cat Hit Counter. The hack gives a stock Lucky Cat some new hardware: a servo, a RGB led, a light sensor, and a 7 segment display. The added components are controlled by an Arduino Ethernet.
The Arduino … Read the rest
WAV music player uses an ATtiny
We’re very accustomed to seeing small media player builds, but [txyz]‘s ATtiny-powered audio player is one of the smallest and most feature-packed we’ve seen.
The audio player is powered by the very small and very inexpensive ATtiny2313. The music is stored on an SD card – a maximum of 2GB of WAV files recorded in mono at 32kBps at an … Read the rest
Blending real objects with 3D prints
It’s very subtle, but if you saw [Greg]‘s 3D printed stone to Lego adapter while walking down the street, it might just cause you to stop mid-stride.
This modification to real objects begin with [Greg] taking dozens of pictures of the target object at many different angles. These pictures are then imported into Agisoft PhotoScan which takes all these photos … Read the rest
NASA is 3D printing rocket engine parts
In case you haven’t heard, NASA is building a new rocket – a replacement for the shuttle – that will eventually take crews again outside low Earth orbit. It’s called the Space Launch System and looks surprisingly similar to the Saturn V that took men to the moon. Manufacturing technology is light years ahead of what it was in the … Read the rest
