[Rob] lives in a 100-year-old house, and with these antique lath and plaster walls and old window frames comes a terrible amount of drafts. The usual way to combat this energy inefficiency is with a thermal imaging camera, a device that overlays the temperature of an object with a video image. These cameras are hideously expensive so [Rob] did what any of us would do and built his own.
The build centers around a Melexis MLX90620 far infrared thermopile that can be had for about $80. Basically, this sensor is a very, very low resolution camera (16×4 pixels) that senses heat instead of light. By sticking this sensor on a breadboard with an Arduino Mini and WiFly network adapter, [Rob] is able to pull the data down from the IR sensor to his iPhone and overlay it on the feed from the camera.
The result, as seen in the video above, is a low-resolution but still very useful thermal imaging camera, perfect for looking for cold drafts in an old house or tracking down [Arnie] just like a Predator.
Tip ‘o the hat to [Ronald] for sending this one in.
Subscribe for weekly videos
Open source, tidy, well executed, and practical. Sweeeet.
That’s a whole bag of win right there! Nicely.
Nice, but for drafts I usually just use Tea Candles. I can imagine this would help locate damp spots though.
Nice! I didn’t know they had an array like that. I’ve been looking at 8×8 and 32×32 arrays, but they’re pricey (qty 100, approx $100 and $400 respectively).
For the curious, that was a year and a half ago: https://forum.sparkfun.com/viewtopic.php?f=5&t=27996
This one, though, is all digital, not a clocked analog signal like those Heimann sensors I had found. the achieveable framerate is very impressive, too (at a loss of accuracy of course).
Very nice, though. thermal cameras can be a pain to use because you can lose your frame of reference to find a thermal point. Now, you may not get all the thermal detail of a standard bolometer, but I think this is great for houses. It’s not like you’re looking for the hot wire in a wire bundle.
They are not that expensive anymore….
http://www.toolbarn.com/milwaukee-2260-21.html?ref=base&gclid=COuC1oKLyrMCFQqe4AodOBAAjw
Dirt cheap at $2500.00 Hell my prosumer HD camcorder cost more than that.
you seem to be unaware of what ‘dirt cheap’ actually means.
+1
LOL But you seem to be unaware that “dirt cheap”, is on of those relative phrases/words like affordable inexpensive:)
“Dirt cheap” is pretty straight forward. I sure as hell wouldn’t pay $2500 for a bag o’ dirt.
In all fairness, he traded money for hours. It would be interesting to know how his work equates in $/hr if you compare it to a commercial option.
But, this is one awesome project and as it’s open source my comment about $/hr is nothing more than an exercise on the back of a napkin.
There’s gold in them thar dirt!
And, less resolution, and this is the cheapest I regularly find
$1200 for a FLIR i3 Compact Thermal Imaging Camera (60×60 resolution)
The FLIR i range are a definite step in the right direction, price wise, but was a bit disapppointed to see they don’t have any sort of video-out connections. A basic composite video connection would be most welcome for connecting to a small DVR/camcorder.
The ones with video out are on the “Restricted Technology – Cannot Export” list in the US, because they make REAL good thermal scopes :-)
Yes, they ARE that expensive. He said they start at $2000 in the video.
I have always wanted one of thees. This is cool – or hot – depends :)Perhaps with some lenses (ZnSe only ones that would work) and Niplow scanning disk arraignment, the resolution could be improved.
You can use a lens made from common table salt (NaCl or KCl). Grow a large crystal and polish it to a lens. This done for DIY CO2 lasers in the “olden days”, and CO2 lasers use the same 10.6 nm wavelength as thermal imagers. You can get ZnSe focusing lenses on ebay for less than $30 shipped. Or you can get polypropylene fresnel thermal imaging lenses for a few dollars: http://www.fresneltech.com/thermalimaging.html
You can also use sapphire lensed for these cameras. They are good up to about 5um.
Oh, and germanium.
Germanium is very expensive. And so is sapphire. If you want to go “all out” you can use a diamond lens (normally used only in extremely high power CO2 lasers). Using a custom diamond lens with a $65 thermal sensor would be a cool hack…
Germanium is used for the lens, but there is a cheaper alternative: polyethylene (it can replace germanium, just like plexiglass can replace glass).
A fresnel lens in polyethylene could be used: http://www.fresneltech.com/thermalimaging.html
Fresnel lenses are used in PIR devices, too:
http://en.wikipedia.org/wiki/Passive_infrared_sensor
http://www.3dlens.com/infraredfresnellens.htm
Very nice
It’s probably worth pointing out that you can rent a nice $2000 professional version with SD card capability from Home Depot for about $50 for a 24-hour period…
For smaller spot work I have successfully used non-contact thermometers to locate cold spots on walls near windows/doors, as well as floor/ceiling areas, to pinpoint where wind/air must be sneaking in.
That is great info. I am going to follow up with them this week to see if they have one. I would like to get some thermal images of the roofs where I work.
More information please.. Mislaid reply below..
I had to hunt around for it on the pages linked, but apparently this is the hardware setup in question: The sensor is an MLX90620, connected to an Arduino, which is in turn connected to a wifi breakout board. The iPhone gets the sensor data via wifi and overlays it with the live video feed.
Oh yes, and the sensor appears to cost around $65 USD.
Here’s a page with instructions, BOM, schematics, etc for building a servo-controlled scanning thermocamera. Takes longer to get an image, I’m sure, but the resolution is much better. URL: http://www.cheap-thermocam.tk/
Nice, remove the IR filter from your iPhone (or Android phone) and you really will have Predatorvision.
Wrong wavelength. All you will get is pink hued images from the overexposure from NIR.
All the (little) information I could find pointed to this: http://www1.flir.com/homedepot. That suggests it is only being done in the Boston area.
drat, wrong thread..
No, you will be able to see near infrared (like the one used by TV remotes), but not thermal infrared.
Near infrared photo can be done by a modified camera, or by a camera with nightshot features. You can also use a filter to block visible light, and get only near infrared: a good filter can be done with a piece of processed photo film. Near infrared photos are very beautiful, but they don’t provide any thermal info.
Read this for more info:
http://www.hoagieshouse.com/IR/
Late reply, but anyone who happens to be going through comments: this sensor array is a TRUE FIR sensor, and can in fact measure um+ wavelengths. It is not a standard CCD/CMOS array, and they are not using the iPhone camera to measure FIR (which is, as you note, stupid). Spend a bit more time reading before deciding to bash a hack?
Nice set-up.
Working on the same:
Discussion about this sensor on XDA:
http://forum.xda-developers.com/showthread.php?t=1780504
Evaluation Board for MLX90620 Temperature Array:
http://www.futureelectronics.com/en/Search.aspx?dsNav=Ntk:PartNumberSearch|MLX90620|1|,Ny:True,Nea:True
That URL contains “unsafe” characters. Here is the “URL encoded” version of that URL:
http://www.futureelectronics.com/en/Search.aspx?dsNav=Ntk:PartNumberSearch%7cMLX90620%7c1%7c
During one of my searches for DIY thermal imaging stuff I found a project someone did, it was a ‘thermal torch’ with an IR temperature sensor and a bunch of bright red,green & blue LEDs.
The idea was whatever you pointed the torch at the LEDs would shine coloured light onto it showing wether it was hot, warm or cold.
If I can find the page again I’ll link it here.
This one?
http://publiclaboratory.org/tool/thermal-photography
I believe this is the original blog site:
http://www.rhworkshop.com/
Since this data is being fed into software on the smartphone, there are loads of applications for this. One that springs to mind would be pointing it at your breadboard, where it could signal an alert if a component became hot enough to burn skin.
That’s very neat. I like that.
I suggest upping the frame rate a bit to say 30fps to be closer to the iphone camera and then try implementing motion tracking in software. That way he could possibly build up a more detailed heat map by sweeping the device around a little instead of holding it steady.
If the response time was adequate, couldn’t you vibrate the sensor and monitor its position to drastically increase resolution?
An idea on how to make a cheap thermal imaging sensor:
http://www.electrooptical.net/index.html#footprints
Working prototypes got made, but it seems that it didn’t get any further.
Another interesting idea is using thermochromic liquid crystals:
http://benkrasnow.blogspot.it/2010/10/low-cost-diy-thermal-imaging-liquid.html
First off, kudos to a really cool idea well implemented. That is really clean.
I’ve looked into that sensor and my main gripe with it is not the resolution, it’s the refresh speed. If it could update around 20-30 times a second, I would be using it for all kinds of things. As it stands it’s possible to get stand alone units with 100×100 pix 5-10 hz on ebay for around 500$. Real time gray scale units for around 900$. (broken high end ones for even cheaper)
For those of you who have never used a highly sensitive thermal imager before, I found an unforeseen useful side effect: the worlds most expensive stud finder. That’s right, the wood support beams can be seen pretty clearly through the wall board. It’s pretty awesome when determining where to install shelf brackets, etc.
