Giving An Apartment Keyless Entry
The key for [rybitski]’s apartment is a copy of a copy of a copy, and the landlord lost the original key years ago. The lock itself still works, but opening it with [rybiski]’s key is a chore. He wanted to make it easier to get into his apartment, and with Arduinos and such he figured he could make a keyless entry device for his front door.
After figuring out how to open his deadbolt with an Arduino and a rather powerful servo, [rybiski] looked into wireless control options. He found a keyless entry remote, complete with receiver, that integrated perfectly to just about any microcontroller project.
After mounting the Arduino, receiver, and servo on a piece of plastic, he attached his contraption to the deadbolt. In the video after the break, you can see his key fob remote locking and unlocking the deadbolt, all without jamming an ill-fitting key into the lock.
[youtube=http://www.youtube.com/watch?v=tHlz93s54dw&w=470]
16 thoughts on “Giving An Apartment Keyless Entry
  1. The keyless entry is cool, but shouldn’t the landlord call a locksmith and re-key the door as soon as the original (or any copies) are lost?
    Properly working locks are a pretty important requirement, in my opinion.
    1. If you have something to start with, a faster way to fix a key is to build up a thick pad of solder on the back of a copy of the troublesome key and file it to a thickness that makes the key work without employing the famous jiggle technique. This will yield a new master, as it won’t be rugged enough for continued use. Really, the copy is in case you don’t have the patience to complete the process (it can be a pain). There may not be anything cooler than when a key finally turns, but impressioning a key from a blank takes quite a while. Also, by the way, most cartridge style key copy machines loose 0.003- 0.004 inches per copy. Lock smiths copies usually don’t fare much better.
  2. “The key for [rybitski]‘s apartment is a copy of a copy of a copy, and the landlord lost the original key years ago.”
    Not the tenant’s problem – and a lock that old/worn is probably useless security-wise.
    Tenants: stand up for yourselves and stop letting landlords treat you like ATMs. Landlords collect over ten thousand dollars in rent a year in most places – they can afford to, once every DECADE, spend a couple hundred dollars on fresh locks.
    1. It’s not like most people have any recourse. You can quote the law all you like but unless you have a lawyer (something most people can’t afford) and take them to court (something almost no one can afford assuming you have a job) nothings going to happen.
      1. Actually small claims court isn’t even necessary in most states. All you have to do is file a grievance with the court and they will set up an escrow account. You pay your rent into that escrow account. The landlord won’t see that rent money until the court is satisfied that the grievance has been answered to their satisfaction.
      2. Or depending on the cost of rekeying and the willingness of your landlord to co-operate with reasonable requests. You call the locksmith yourself get it replaced, make copies of the receipt and send them in with next months rent minus the cost of the new lock.
  3. I do rental homes and rekeying after each tenant, worth the 60 bucks to insure the previous tenant didn’t hand out keys to bad people. This is still a cool rig though, props on not defacing the property n the process.
Leave a Reply to Kris DamonCancel reply
