[Chris] set out to build a monitoring system for his water heater. It doesn’t Tweet or send SMS messages. It simply lights up an LED when the water heater is active. The one thing that complicates the setup is that he didn’t want to pull any wire from the garage into the house. What you see above is the wireless setup he used to accomplish this goal.
This is an electric water heater, so [Chris] patched into the 230V heating element feed. When the water heater is idle this connection is cut off. He used a transformer to step the voltage down to 17V and rectified it before feeding a 7805 power regulator. The rest of the transmitter circuit consists of a 555 timer driving the coil seen on the left. It is made out of telephone wire, with each of the four conductors inside connected together to multiply the number of windings. The box of breakfast sausages hosts the receiver coil. His hardware takes the induced current from that coil and amplifies it, feeding the signal to the base of a transistor responsible for switching the status LED. This works through the 6″ thick garage wall, although he did have to use a battery on the receiving end as his wall wart was injecting way too much noise into the system to work.
Subscribe for weekly videos
Too much noise from the wall wart? I’d think that a simple LDO regulator plus a couple of caps would fix that (for under $1 worth of parts).
Hey, he used a box of breakfast sausages as a project housing, maybe he didn’t have the dollar to spare? :)
I think this is brilliant, partly for the MacGyver attitude, but mostly for the approach:
I need to get an electrical signal from here to there.
I have a reel of cable.
I know – wireless transmitter/receiver combo!
So in the transmitter circuit, the {L1, D2, D1} convert the 5V DC to AC from the 10KHz 555 signal? I have always had the notion that oscillations required an inductor / capacitor combination. Is the zener assisting this transformation?
Also, I am guessing that the only reason he had to use a 555 is to get a higher frequency that would pass through a wall as opposed to the 50hz?
The 10KHz signal from the 555 *is* AC. You can’t use the 50Hz from the mains directly because you’ll pick up signal from all the wiring in your house, not just the heater.
L1 is the transmitter coil.
Award for most inefficient way to light an LED
^ +1
“The box of breakfast sausages hosts the receiver coil.”
I want to write a cold war spy novel around this sentence.
When I first got into building electronics, I was inspired by wartime “POW” radios, that I built a one-tube battery operated AM radio into an old First Aid Tin.
One of these days, I should fit one into a canteen…
So ghetto it hurts (this rules).
One for the nit pickers:
I haven’t thought about coils for a while.
Would that steel(?) core wire tie holding the coil
have an affect on it?
..and not even a bit of Scotch (brand) tape ['nother budget concern?]
on the wires.
I fully expect you curmudgeons to rip it apart.
in all seriousness though, if it’s not a *big* shock or fire risk
then I love stuff like this.
..was the way we did things when i was a kid.
Heck, A good tingle can be educational ;)
a simpler way maybe to use 2 tv coils (if you have taken apart 2 color tvs) that has a neck coil (sony winds it around a plastic ring attached to yoke others it is a 5 or 6 inch diameter ring of very thin wire)
and wire a resistor to limit the current that is the transmitter.
the receiver just a resistor to limit the the current and a diode to make dc and an led.
you may need a smaller coil for the receiver since you may get 110 to 220 out of the receiver.
you are right about not wanting to drill holes since if the house is a rental unit the land lord may not like holes or may take your security deposit to repair holes.
In my case it’s a gas burner that sounds like a jet taking off. So all I have to listen for is noise.
What really amazes me is that he eats Jimmy Dean Sausage Biscuits and he’s still alive!
