Hackaday Links November 22nd 2012
HDD Grinder
hdd-grinder1
As [unicorn] described it, “this is no big thing.”  We would agree, but a grinder made from a hard disk drive at least deserves to be in a [HAD] links post. Here’s the original source.
The No-Video Game
no-video-game
What do you get when take [Sub Hunt] and take away the ability to see what you’re playing with? The No-Video Game is what [Sean] at [Hive76] came up with. Thanks [Kyle] for writing in to tell us about it!
SD Card Hack ‘N Slash
sd-card-slashed1
[Paul] wrote in to tell us about his friend [Ahmad's] discovery that you can cut a standard SD card in two and still have it function. Sure, some people know this, but we’d be willing to bet most don’t. In the pictures provided, it makes for a nice upgrade to the Raspberry Pi’s form factor.
FM Transmitter for FPGA
fm-sos
[Hamster] wrote in to tell us about how he added an FM tranmitter to his field programmable gate array project. Check out the wiki for the code to do this with, or this Youtube video to see it in action!
Brute Force Hack a Garmin GPS
brute-force-gps
Although there’s only a Youtube video to describe this hack, it’s really worth seeing.  Some people might go with a pure electrical method to open up their Garmin GPS, but why do that when you can “just” create an array of fingers to do it for you! Thanks [David] for the tip!
Comments
  1. CraigBurden says:
    Hmmmm, I want to try the SD card trick but I don’t really want to risk it! Maybe if I can find a small one
  2. jc says:
    the sd trick doesn’t work with all cards. But its usually pretty easy to open them before, see what you can cut out, glue it together and then cut it.
  3. TomF says:
    Does anyone still have RS-MMC cards? I got a 2GB version, bought for an ancient mobil phone. It is basically a shortened SD-card with some extra conctacts. Perfect for the RPI, but unfortunately not available with higher capacities.
  4. Hirudinea says:
    I like the no video video game, now that Tommy guy has something to play besides pinball.
  5. vonskippy says:
    re: cutting SD cards
    Wow, I can’t imagine what I’ll do with all those saved 2 cm’s.
    No really, I don’t get what such a tiny amount of saved space brings to the project.
    If space is really tight, use a micro-sd card.
  6. biozz says:
    for the sd card i used to do this allot but wow they have gotten far smaller than what they used to!!!
    and for the GPS password thing … you can do the “secret” reset or crack her open and dump the eeprom XD or erase the eeprom! … its stored in plain text! (ascii)
  7. Justin says:
    FPGA are the new SDR!
  8. JoeDontCry says:
    The GPS thing reminds me of http://www.youtube.com/watch?v=iK_6yB45__k
  9. mowcius says:
    I know for a fact that the SanDisk Extreme Pro cards *cannot* simply be cut in half.
    As you can see from the translucent nature of them, the memory chips pretty much fill the thing.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
