OLED name badge with rechargeable LiPo cell
oleduino-name-badge
Here’s a project that let [Rick Pannen] try his hand with an OLED display and a rechargeable power source. He calls it OLEDuino which is a mashup of the display type and the Arduino compatible chip running the whole thing. He figures it will serve nicely as a geeky name badge but also ported a Breakout type game to play when he’s bored.
The project is an inexpensive way to attempt a more permanent trinket than simply using Arduino and a breadboard. [Rick] sourced the OLED display and USB LiPo charging cable on eBay. The ATmega328 hiding below the display is being driven from the 3.7V LiPo cell without any power regulation. The four buttons at the bottom provide the only user input but it should be more than enough for a few simple tricks.
Head over to his code repo for a bit more information. The schematic and board are both Eagle files. We generated an image of the schematic and embedded it after the break if you want to take a quick look at how simple the hardware really is.
oleduino
Comments
  1. E-ink says:
    This would be better if it were e-ink
  2. gr0wlithe says:
    With a little extra effort this could be a multifunctional watch!
  3. xorpunk says:
    stack it all and move button closer to oled, 3d print a case for it.
    I want to do this with a efficient cortex-m4f or cortex-a 3xxx just to mess with low level armv7 coding and hardware.
    • xorpunk says:
      you could also use a smaller cell, maybe research more durable rechargeable that meat the power requirements.
    • dizot says:
      I definitely like this. Just needs a little more refinement.
      I’ve got a tiny [2"x1"] development platform I’m working with all of the recharging, USB-serial, mic, speaker, joystick, etc built-in. It’s a work in progress. I’ve also got a stripped-down version that just functions as oscilloscope / spectrum analyzer for a wearable pendant [just waiting for the boards].
      bitpuppy.com
  4. jaromir says:
  5. Whatnot says:
    Would look nice stuck to a large pack of clay with wires coming from it :)
  6. dnmeboy says:
    Where did you get the lipo? It looks identical to the ones inside of the ecigs I use.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,740 other followers
