Macro assembly for AVR chips
avr-macro-assembly
Here’s an interesting tip that can help improve your ability to write assembly code. In an effort to remove the complexity of assembly code for an AVR project [Quinn Dunki] figured out how to use macros when writing AVR code with the GNU toolchain. Anyone using AVR-GCC should keep this in mind if they ever want or need to … Read the rest
Twitter radio
twitter-radio
This anthropomorphized wood bowl will read Tweets out loud. It was built by [William Lindmeier] as part of his graduate work in the Interactive Telecommunications Program (ITP) at New York University. View the clip after the break to see and hear a list from his Twitter feed read in rather pleasant text-to-speech voices.
The electronics involved are rather convoluted. … Read the rest
LiPo internal resistance measurement tool
lipo-internal-resistance-meter
This is a scratch-build meter for measuring the internal resistance of Lithium Polymer cells. [Bleuer Csaba] uses the LiPo cells for RC vehicles and thet take quite a beating from the motors  they’re supplying. This means that he only gets about 100-200 cycles out of each cell. To figure out where one is in its life cycle you can … Read the rest
Super slim wristwatch build
super-slim-wristwatch-build
This slmwtch lives up to its name. When the LCD screen is folded back onto the PCB the entire thing comes in at just 2.35mm. That’s including a coin-cell battery not shown above. Wow!
Part of what makes this possible is the specialized PCB design. [Anders] didn’t want to add more thickness than the screen and battery so he … Read the rest
Unlocking Verizon Galaxy Note II and Galaxy S3
galaxy-note-II-verizon-unlock
[Adam Outler] and friends have been hard at work unlocking the bootloader of some Verizon Android devices. His most recent adventure involves unlocking the Verizon branded Samsung Galaxy Note II.
You can’t run Cyanogenmod on a device that has a locked bootloader. This is presumably why it took no time at all for the XDA forum users with Verizon … Read the rest
Observe a satellite’s Morse Code message today!
Niwaka1-satellite
If you live in the Eastern portion of the United States and the skies are clear you can see a student built satellite flashing LEDs in Morse Code today. But don’t worry. If you it’s cloudy or if you live elsewhere there are several other opportunities to see it in the coming days.
This is the Niwaka Fitsat-1. It … Read the rest
Tablet rig takes sheet music digital
music-stand-tablet-holder
[Bill Dudley's] wife wanted to use a couple of different tablets for displaying sheet music. Sure, a proper music stand will have no trouble supporting the weight of the device, but if it’s not secured it place you may soon have a broken device. [Bill's] solution was to build this tablet stand out of PVC.
The image above doesn’t … Read the rest
