Building a tornado in a bottle
vortex-tornado-machine
Recreate the look of a tornado by building this water vortex art piece. The components that go into it are all very simple and can be found in your recycling bin with the exception of a motor and a way to drive it. The hard part is going to be getting to the point where you don’t have any leaks.
[Ixisuprflyixi] went with an empty salsa bottle to house the vortex. It’s a pleasant shape for the project since it’s both tall and narrow and it’s got a bit of a sexy curve to it. The base of the machine is a plastic bottle which looks like it might have been for Metamucil, but we’re not sure.  The important part is that it needs to be made from HDPE, as a portion of the container will be used to make the impeller. That’s the part that attaches to the motor shaft inside of the container. Give it a spin and you’ve got yourself a tornado in a bottle. See it in action after the jump.
This is a much quicker and easier version than the one we saw [Ben Krasnow] build. He ended up doing some repair work on the gasket that seals the motor shaft. It’s an interesting read if you are thinking of building one of these yourself.
[Thanks Mark]
Comments
  1. Necromant says:
    Looks awesome.
    Не побоюсь этого слова – буря в стакане.
  2. MrBishop says:
    Very pretty, makes me want one. although I would have to find a way to make it silent and prevent the light from bleeding though the base. Maybe placing a container within a container then having a layer of insolation would work. Cool stuff, I will have to give the build a look at.
  3. David Rysdam says:
    Kitchen blender.
  4. Haku says:
    I bought a tornado machine from Tesco for £2.50 last week; a self-stirring mug.
    Low battery power:
    Full battery power:
    I’ve also been undervolting the Tesco £2.50 USB plasma ball to produce just a few strands of light instead of filling up the entire globe::
  5. Whatnot says:
    Little tip: they sell ‘milk/coffee foamers’ for cheap with a little motor that already have a rubber seal on the shaft, they go for as low as $1 and look like this: http://www.alibaba.com/product-gs/534755144/New_Battery_Milk_Foamer_Whisk_Coffee/showimage.html
    Image is random from web search.
    Not sure the seal as delivered can withstand the pressure of a container filled like that though.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,357 other followers
