Put that headphone jack anywhere you want it
yamaha-keyboard-headphone-jack-hack
Check out this brand new Yamaha keyboard. The fact that we’re seeing the guts means that [Todd Harrison] can kiss his warranty goodbye. But by now you should know that he doesn’t look to others when something goes wrong with his electronics. This time around he’s not repairing anything. He didn’t like having to plug in headphones on the rear of the keyboard. He cracked it open and relocated the headphone jack to a more convenient location.
As you can see, there’s a ton of room inside once the MDF base which holds the speakers and some sounding boxes has been removed. While he’s in there he takes a good look at the mechanics of the keys. They’re weighted with metal rods (seen above) to help the electronic instrument feel more like an acoustic version to the player. But he doesn’t neglect the chance to gawk at all the electronics as well.
After pulling out the PCB that has the headphone jack on it he goes to work with a solder sucker. With the solder gone he cuts through the glue that holds the jack on the board. All that’s left is to solder some wire in its place and give it a nice project box as an enclosure. To complete the hack he mounts the box on the MDF base and now the headphones connect on the front. See the entire process in the video after the break.
16 thoughts on “Put that headphone jack anywhere you want it
  1. add more functionality by adding a “line in” socket to the keyboard. done right you have another 1/4″ on the back called line in and the whole thing looks unmolested. after that the world is your oyster you can leave both jacks in and bypass feed in do whatever you like outside of the pretty box
    1. Wouldn’t have worked. It is a mechanical switching socket, plug jack in, speakers switch off. If you just wired another up in parallel with it, the speakers would still be switched on when you used it, defeating the purpose entirely.
        1. I did wonder why this wasn’t done. i suppose the argument is that he didnt want to make an extra hole or route inside the case. overall the very simplest solution eluded to by Ruud further up is use an extension and switch it with a toggle. (still believe that music tech you pay this much for should have designed this issue out)
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
