Van de Graaff generator built for a few dollars
2-dollar-van-de-graaff-generator
This Van de Graaf generator was built using mostly parts on hand. The only thing that was purchased for the project was the Christmas ornament shaped M&M candy tin that serves as the collecting sphere. We didn’t include the in-action shot in the banner because it’s so dark. But sure enough, this will generate the visible sparks that make the device famous.
The gist of the device is that it uses rotating belt to generate static electricity. This potential is stored in the metal collecting sphere on top until a path for discharge is provided. They’re an awful lot of fun in middle-school science class as long hair can be made to stand on end if you touch one while your body is insulated from ground. This build uses a long rubber band as the belt. The band is moved by the motor from a DVD drive tray which is housed in the PVC base. An empty prescription pill bottle bridges the gap between the base and the metal sphere.
If this one is too small for you consider moving to a 900,000 Volt version.
[via Hacked Gadgets]
4 thoughts on “Van de Graaff generator built for a few dollars
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
