Hardware SPI with Python on a Raspberry Pi
raspi_arduino_spi
While the Raspberry Pi has very good support for an I2C bus, a lot of very cool chips – including the in system programmer for just about every ATtiny and ATmega microcontroller – use an SPI bus. [Louis] sent in a tutorial for getting hardware SPI on his Raspi, and even though it’s rather limited right now, it’s a step in the right direction.
Previously, [Brian Hensley] put up a tutorial for using the Linux SPI drivers with the Raspi. [Louis] wanted to play with SPI in Python, so he added a C extension to the spidev.c file (available here) that allows him to open an SPI connection, initialize, transfer, and close the connection.
After connecting an Arduino to the MOSI, MISO and SCK pins of his Arduino, [Louis] was able to transfer data from his Raspi over an SPI bus. It should be noted that a level shifter would be a really good idea here, but this is an excellent project if anyone would ever want to port AVRDude to Python.
Comments
  1. antiomiae says:
    At first I thought this post was saying the drivers most people were using weren’t the hardware drivers but were the bit bang drivers. It looks like that’s not the case. I think this Python module will be very useful to a lot people.
  2. Relic says:
    Well he’s missing using a GPIO line from the raspberry Pi to pull the RESET line on the ICSP interface low.
    Implementing that (and the obvious level converter) then you could make a “shield” for the Pi to program most AVR’s out there, either by plugging them into DIP sockets, or a 6pin and a 10pin ICSP header.
  3. Sam says:
    http://www.piborg.org has some SPI drivers for the Raspberry Pi – it’s for their board, but none the less quite useful open source stuff
  4. Oscar says:
    Wrong image
    You can NOT join arduino pins with raspberry pi pins directly, they use different voltage levels and you will break the rapsberry ones.
  5. lloyd says:
    The Adafruit modified version of Raspbian comes with hardware SPI and I2C support: http://learn.adafruit.com/adafruit-raspberry-pi-educational-linux-distro/overview
    • Louis says:
      As far as I could tell from documentation, their SPI and I2C support enables the hardware which is the first half of my tutorial, which is just a summary of Brian’s tutorial.
      I wanted to access hardware SPI from Python and this was the easiest way for me figure out how to do it…
    • As far as I could tell, their distribution voids the first half of the tutorial which is based off of what Brian did.
      The second half is about making that hardware accessible to Python with the C extension.
  6. Hack Man says:
    Why can’t somebody combine an Arduino + rPi on one board?
  7. Cyrus007 says:
    Gordon’s modifications to avrdude for RPi can already program AVRs using SPI, +3V3 and GND. Check out this blog – https://projects.drogon.net/raspberry-pi/gertboard/arduino-ide-installation-isp/.
  8. AC says:
    You can use the FTDI chips to do USB-SPI and USB-I2C. Just saying…
  9. William says:
    So how does this work without a level shifter? Isn’t this likely to damage the Raspi?
  10. wbphelps says:
    Isn’t this likely to damage the Raspi without a level shifter or current limiting resistors?
  11. bartekz says:
    Note that Atmega8 and Atmega168 can run on 3.3V so problem with power levels is solved.
  12. William says:
    The example shows connecting an RPi directly to an Arduino, which runs on 5V. So while an Atmega can run at 3.3, that doesn’t really address the issue here. It may be posible to use current limiting resistors (not shown in the above diagram) to prevent damage to the RPi. Without that, you risk permanent damage to the RPi if you try to transfer data FROM the Arduino.
  13. JimW says:
    Some Arduinos run at 3.3V (e.g. the Arduino Pro Mini 3.3V). If you use one of these then you won’t need a level shifter. If you use a ‘normal’ Arduino (e.g. Uno) then you will get the Raspi a bit upset and probably break it quite comprehensively.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,687 other followers
