Iron Man Faux Stained Glass Saves $4k
ironman-faux-stained-glass
Check out how the light hits this piece of artwork. It’s a very convincing piece of stained glass… except it’s fake. [Sdtacoma] figured out a way to mimic stained glass using a single pane. The inspiration for the project came after seeing a real stained glass panel featuring Iron Man which was available on Etsy for $4500.
Due to popular demand [Sdtacoma] posted an album of the technique he used. Starting with some art found online he made it black and white, blew it up to size (this thing’s about five feet tall) and used posterizer to print it out using multiple sheets of paper.
The frame and pane were found at a recycled building goods store. After cleaning it up he used the paper template to lay out the dividing lines between different colored sections using Liquid Lead. The product had dimension to it (kind of like puffy paint for fabrics) which looks like the lead tracks between panes of stained glass. Once dry the color was added using an eye dropper to apply glass paint.
28 thoughts on “Iron Man Faux Stained Glass Saves $4k
    1. No, it doesn’t. First off, he’s used shit supplies. “Liquid Lead” is just Acrylic, and he filled the pieces in with cheap transparent paint, Both of which love to peel off in the summer. and also, this is a blatant rip off of my design found here: http://senatormars.deviantart.com. I don’t consider Imitation to be flattery in this case because his technique is crap.
      I doubt this hack could design his own work, and his half ass attempt to “credit” me loses some of it’s sincerity when he spells my name wrong. Oh, and At least I made sure i linked to the original artist that I designed my pattern around:
      http://cellophane-s.deviantart.com
        1. I don’t think this “hack” looks better than the original at all, It’s a bastardization of the original design and the quality just looks poor. I”m sure you don’t understand anything about stained glass, and I don’t know if your white trash point of view is really legitimate anyway
    2. Someone should mention how this amazing “Hack” “saved 4k” Is made with materials that are going to peel and fall off, fade, crack, and chip within a year. Any reasonable exposure to the sun is going to fade the colors considerably! I think this is a misleading title, It’s like saying someone saved 50k by making their own mercedes benz! This isn’t a “hack” This is some losers craft project.
  1. Not a great imitation… Real stained glass must be made of pieces you can cut & snap off. The background here has too many incuts for that. If you look at the Etsy, that’s the purpose for the “artsy grid” behind Iron Man – if you look, the lines all touch the outermost curve of the suit for the area. This is so the squares of the background only had to have corners cut off, so no in-cuts.
      1. Well, yes and no. If you knew what an incut was, then you’d be more on the ‘No’ side.
        Imaging cutting the letter V. That sharp corner inside the letter is very hard to cut by hand, and even if cut using a ring saw (or waterjet etc) it’s a stress point that may break on its own later. Pieces like that are often made in two pieces.
        A similar situation exists for rings, these are usually made from 4 curves.
        Sharp corners, thin pieces, cut-outs etc are a pain and need to be avoided.
        That said, there doesn’t seem to be anything on that design that’d cause problems when cut out of glass.
  2. At the primary school I went to, a lot of the windows had pictures on where they’d used a similar method to this, I thought this was pretty common to be honest. This is far cooler than rainbows and the alphabet though and I want it.
  3. Did you guys even bother to read the article? He did not “figure out” how to do this. Faux stained glass using “liquid lead” has been around for ages. My mom has pieces she made back in the ’60s — and it wasn’t even a new concept back then! And anybody — anybody! — can do this; mom help me make several when I was eight or nine years old.
    That said, props to the fellow who made this; I’m a fan of the movies, and I would *totally* hang this in my workspace! :D
    1. he figured t out for himself how to do it, the technique yes has been around for a while, but HE figured it out on HIS OWN. not like he’s saying he created the technique. why do people have to rain on other people’s parades. I’d like to see you come out with one.
Leave a Reply to pcf11Cancel reply
