Finding 1s And 0s With A Microscope And Computer Vision
ROM
One day, [Adam] was asked if he would like to take part in a little project. A mad scientist come engineer at [Adam]’s job had just removed the plastic casing from a IC, and wanted a little help decoding the information on a masked ROM. These ROMs are basically just data etched directly into silicon, so the only way to actually read the data is with some nitric acid and a microscope. [Adam] was more than up for the challenge, but not wanting to count out thousands of 1s and 0s etched into a chip, he figured out a way to let a computer do it with some clever programming and computer vision.
[Adam] has used OpenCV before, but the macro image of the masked ROM had a lot of extraneous information; there were gaps in the columns of bits, and letting a computer do all the work would result in crap data. His solution was to semi-automate the process of counting 1s and 0s by selecting a grid by hand and letting image processing software do the rest of the work.
This work resulted in rompar, a tool to decode the data on de-packaged ROMs. It works very well – [Adam] was able to successfully decode the ROM and netted the machine codes for the object of his reverse engineering.
18 thoughts on “Finding 1s And 0s With A Microscope And Computer Vision
    1. You’d be surprised. Old tech is used in new systems all the time. There’s a wise old saying “If it ain’t broke, don’t fix it!”, which, in my experience of the IT Security industry should be amended to: “If it ain’t *very publicly* broke, don’t fix it!”. :P
      That was a good talk though – I’m a big fan of both Chris & Karsten.
Leave a Reply to waltCancel reply
