Uzebox Coding Challenge
Uzebox Coding Challenge 2013
The 2013 Uzebox Coding Challenge is currently underway. This competition runs until June 1st, with registration open until April 1st. The Uzebox is an open source, 8 bit game console that uses only two chips: an ATmega644 microcontroller and a AD725 RGB to NTSC converter. We’ve featured it a few times in the past.
The competition rules are pretty loose: build a game or a useful piece of software that runs on the Uzebox, and fits in 61 kB. Entries will be judged on game play, originality, graphics, sound, completeness, and technical prowess. There’s prizes for the top six entries, including a few Uzeboxes and cash.
If you don’t have an Uzebox, check out the Uzem emulator. This lets you emulate the Uzebox hardware on Windows, Mac, or Linux. The emulator also has an internal GDB debug server to help with development. The low cost console can be built for about $30, and a number of kits are available.
Thanks to [Ben] for sending this in.
9 thoughts on “Uzebox Coding Challenge
  1. The problem with this console is, that the program/game sits in the flash (program) memory. Yes, there is an SD card slot, but the app is read from it and saved in the flash (remember about finite number of write cyles!).
    1. So according to the datasheet, it’s good for 10k write cycles minimum. So if you play 10 different games from the SD card for 365 days a year, that’s ~2.7 years of play time.
      Luckily, the 40pin DIP Atmega644 is easily swapped out in case you’re that big a fanatic of the Uzebox, and at a cost of $7 to $8 per individual uC it can be easily swapped out.
      Don’t let the flash write cycles scare you!
  2. Guess I might be participating in this one, and i might pick up the soldering iron again, its been a while. I had all the parts i needed just lying just collecting dust.
Leave a Reply to cunning_fellowCancel reply
