Giving An Electric RC Plane An Afterburner
RC Afterburner
The folks at Flitetest decided to add some extra power to an electric DH.100 Vampire RC plane by adding a butane afterburner. After some testing, and a bit of fire, they were able to make it fly.
Their afterburner uses a small butane canister for fuel. A servo motor actuates the valve on the canister, forcing fuel into a tube. This tube is set up to regulate the flow of butane and ensure it vaporizes before reaching the afterburner.
At the afterburner, a circular piece of tubing with holes is used to dispense fuel, much like a barbecue. This tube is connected to one side of a stun gun’s flyback generator, and the metal surrounding it is connected to the other. The stun gun creates sparks across the gap and ignites the fuel.
With the extra components added, the landing gear was removed to save weight and the plane was given a nice coat of paint. They started it up for a test run, and the plane’s body caught fire. After some rework, they managed to take off, start the afterburner, fly around, and belly land the plane. It achieved some additional thrust, but also sounds and looks awesome.
After the break, check out a video walkthrough and demo. We promise you fire.
40 thoughts on “Giving An Electric RC Plane An Afterburner
  1. But… That’s just aesthetics? Is the “afterburner” giving extra throttle power?
    If it’s for aesthetics, then it’s ok (the model itself is not a big deal, and the blue flame in the twilight is a very nice effect!)
    But if the purpose were to add some functional afterburner system, I don’t think this gonna worth it.
          1. You can’t really test static thrust on a high RPM setup like this – Air speed has considerable affect on thrust.
            Didn’t you ever fly an RC plane before?
      1. Actually no. A hot engine is probably not going to be hot enough to start a fire. They do not glow red hot folks and most do not use any kind of spark. Model rockets tend to burn out very quickly so be the time they hit ground they are not producing thrust. Also model rockets are made of wood and paper to start with….
        Yea I would recommend anyone flying this plane to not fly it in fire conditions and to use their brain.
  2. Sounds neat -but more thrust – bwahahahahaha – dream on.
    The electric fan doesn’t accelerate or compress the butane enough to make a difference – butane doesn’t have enough chemical energy to make 15% difference – and the thrust chamber is way to open in order to see any significant increase in thrust.
    But it does sound & look cool – way better then the normal electric motor whine.
    1. Why not? The butane flame causes the exhaust gases to heat up, thus expanding, thereby increasing their speed, which leads to higher thrust. The same principle as the real afterburner, except it has an impeller instead of an engine
      1. Did you know that during testing the P51 mustang gained measurable speed under certain conditions strictly from the design and location of the vent port for the engine? The heat generated by the engine caused the air inducted for cooling to expand and accelerate as it left the engine compartment generating some additional thrust. It was totally unexpected apparently.
  3. For those of you who dont already know David, he is an accomplished RC pilot and a skilled scratchbuilder. He is one of several pioneers in FPV, and has created a lot of cool content, both video and DIY related. You should check out his site sometime if you would like to learn more!
  4. Neat system to be used on something like a R/C SR-71. Not to belittle this thing, but the Vampire never had an afterburner to the best of my knowledge, also the scream of the Ghost, Goblin or Nene engines resemble the whine of a ducted fan.
    On the other hand… this is loud, fast, potentially lethal and there is fire involved. Perfect.
  5. You cannot possibly make something like this and not put a machine gun on it, and film it strafe a few barnyard animals. Come on!
    Just kidding. It sounds and looks fantastic. Well done.
Leave a Reply to colecoman1982Cancel reply
