Another Way To Look At Charlieplexing
Charlieplexing is a technique that allows you to drive a larger number of LEDs than wouldn’t be possible with the same number of I/O pins on a traditional multiplexed matrix. If we lost you there just think of it as lots of blinky lights connected to a small number of pins. It works by leveraging the one-way nature of a diode. Current will only flow through an LED in one direction so if you hook up your display in a clever way you can drive multiple LEDs from one I/O by switching the polarity of that pin between voltage and ground. [M.Rule] recently looked at using Charlieplexing with LED modules. His conceptual approach to the problem is different from those we remember seeing before and it’s worth a look.
Instead of just using the formula to calculate how many LEDs he can drive [M.Rule] is using a table of I/O pins to establish how many and in what order these displays can be connected. Each colored set of blocks represents an LED module. The graphic above shows how 18-pin can be utilized. He even filled in the unused pin combinations with input buttons.
7 thoughts on “Another Way To Look At Charlieplexing
  1. Where is a good place for a tutorial on this? I’d like to make a big audio visualizer display in my new house (one day if I can stop buying every electronic along the way). What are some other good electronic projects places as I trying to learn more by building, seems to make more sense to me that way.
    Humbly,
    Roo
