14 thoughts on “The Construction Of An Triode, By Hand
  1. Please fix the title of this article — it confuses readers :). Video is titled “Fabrication d’une lampe triode”, i.e. fabrication of a triode. “Les electrodes” is the name of first part of the video where electrodes are being made.
  2. This brings back the magic from long ago. You can’t look into a modern integrated circuit or even a transistor and see the working parts of the device (at least not without something to remove the epoxy and a high power microscope system).
    A thermionic valve (electron tube) has three electrodes, a (usually heated) cathode, a control grid, and an anode. A pentode has all that and a suppressor grid and screen grid.
    The common term in French for a valve (or tube) is ‘lampe’ – because it glows.
Leave a Reply to Just SoCancel reply
