The Trials Of Repairing A MacBook
mac
As a favor to a friend, [Phil] traded a unibody MacBook logic board for one with a broken headphone jack, a busted keyboard controller, and a nonfunctional fan. Not one to let bad hardware go to waste, he set off to repair this now-broken laptop by scavenging parts wherever he could. The whole thing ended up working, and became a very impressive display of soldering skill in the process.
The first step for the keyboard transplant was to cut a properly sized hole in the newer unibody MacBook for an older, pre-unibody MacBook Pro 17″ keyboard. This was done by cutting out the keyboard pan of the pre-unibody case and very carefully epoxying it into the unibody chassis. The MBP had a separate keyboard and trackpad controller, so of course [Paul] needed to find some space inside the chassis for these new electronics. This space was found next to the internal hard drive, and a liberal application of hot glue held everything together.
In the future, [Phil] plans on adding more LEDs, a 3.5 mm jack, and a USB to TTL converter – a necessity for any true ‘hacker’ laptop. It’s still a wonderful piece of work, and an incredible amount of effort and skill to get it where it is today.
30 thoughts on “The Trials Of Repairing A MacBook
    1. Because the keyboard controller on his logic board wasn’t working. The PU keyboard has it’s own controller and can be connected as a USB device. Thus allowing him to use the ‘broken’ logic board.
  1. Hot glue? Well chewed gum is organic and a much better glue when it drys out. It is amazing what watered down crap is sold in stores as adhesives. The public is kept from the good stuff because of huffers and the EPA.
    1. I use hot glue because its not a pain to get off something after I put it on. It comes off in one piece without much effort or tools involved. If I really wanted something to stick there is epoxy for that.
      1. Hot glue is a great adhesive. Try squirting a blob of hot glue on almost anything, let it cool without smearing it. Then put a few drops of rubbing alcohol on it and give the glue a little tug. The alcohol breaks the bond and forces the glue to let go. I have tried this with a bunch of types of hot glue and materials and the result is the same every time. It really is great for small model airplanes and electronics where you want to quickly mount something and remove it later.
    2. I wonder what kind of person it takes to snip duck tape and electrical tape. Last few rolls I bought were garbage, ultimately had to melt the electrical tape to itself to get it to stick, and the duck tape I had to tie.
      1. You both make good points and here is my two cents, well actually my dad’s two cents since he hangs out at Lowe’s to escape family functions.
        He noticed the same thing you did: The glue on the new tape is crap. His pointer from one of his Lowe’s buddies is to go for the Pro stuff or Contractor Special Rolls as the regular electrical tape and duct tape on the shelf is all China crap and the same stuff they sell at the dollar tree. The pro and contractor level stuff is higher grade and indeed has more/better glue. I always steal a couple of rolls when I am at home visiting :)
        Gaffer’s tape is good stuff, but a beast on removal. I had two synths that I literally had to dremel the stuff off of as it had been on there for decades. No alcohol/goo gone/ or oils would budge the bottom coat lol. Impressive indeed! If you have any removal techniques I would love to hear them :)
  2. Simultaneously great and . . .rough work. I can’t speak for everyone, but I bet that a lot of apple service providers have trashed case tops for that model laying around. We probably have dozens for that model in our scrap piles in the back room. Nice work on kludging the 17incher trackpad in though :).
Leave a Reply to TargetAlphaCancel reply
