Resistance Decade Box Using DIP Switches
resistance-decade-box
Here’s a simple piece of equipment which you’ll be proud to display on your electronics bench. It’s a resistance decade box. The concept has been around forever — it offers the ability to tune a wide range of resistance values just by adjusting the controls. We especially like the clean look of this one, and think the use of DIP switches is a nice touch.
Check out the toggle switch at the top. It lets you disconnect the resistance values from the output in order to test them with your meter. It may not seem like much, but fudging your switch settings could end up smoking your target project. The value of that feature isn’t lost on us.
The DIP switches are mounted to some Radio Shack breakout boards which work perfectly for hosting the resistors as well. This keeps the inside of the enclosure nice and tidy. The final touch is the printed face plate applied to the cover of the box.
Like we’ve said, this one is nice but our favorite is still this one that uses thumbwheel switches to dial in a value.
20 thoughts on “Resistance Decade Box Using DIP Switches
  1. Nice and clean. Building something like this is on my list of things to do.
    Just wanted to point out: doesn’t “decade” imply factors of 10 (1, 10, 100, 1k, etc.)?
    1. Yeah, I thought about the “decade” thing. But the term “Decade Box” means something to people in electronics and I wanted to make sure the device’s purpose was clear. Binary Box just didn’t cut it! Thanks for your comment.
    1. Thanks, Pete! I share your concern. I’m primarily working with 5V, low current circuits, but I looked around for the sturdiest DIP switches I could find and settled on GC Electronics 35-968. They’re rated at 100mA @ 50V carry and 100mA @ 5V (or 25mA @ 25V) switch.
    1. They’re 5% resistors and, of course, your point is valid. That’s exactly why I included the ohmmeter binding posts and adjustment rheostat. With them, I can make sure my resistance is right on the mark before I put it into my circuit.
  2. That switch and lead set to the multimeter is brilliant, not only can you check your resistance but also flip the resistance in and out of circuit easily without fiddling with the wires.
  3. Well, if you’re using rheostats, why not go to the end with them: put 4-5 of them in series (increasing resistance) and you can adjust the values much faster. I think you still have to use the ohmmeter output when setting the values (unless you can convert to binary in your head really fast) so you’re not losing any functionality…
    If you can find some double rheostats, you could expose one circuit to the outside and one of them to a voltmeter from inside so you could have a display included :D
      1. I think the multiple rheostats design would be a nice project. I really built this one because I needed a resistor box and I haven’t seen any using DIP switches or binary numbers. Just a geeky thing I guess, but it was fun to build and it comes in handy on my bench!
  4. can this box be used for data lines that sense switches ? been racking my brains for time with a project finally realize its to do with switches any help would be grateful
Leave a Reply to junkboxCancel reply
