75 Controllers, One Gaming System
Multi Video Games System
This gaming cabinet lets two players select games from a wide array of consoles and play them using the original controllers. [Patrice] built it around his Multi Video Games System 2, which converts each of the 75 controllers to a common format. Players pick controllers from the display case, plug in an  HD-15 connector, and choose the game they want to play. The cabinet contains a PC that runs a variety of emulators, and uses HyperSpin as a menu system.
Using adapters, the converted controllers can also be used on other game systems, tablets, or smartphones. [Patrice] claims that they’ll work across 110 different game systems. A full list of the controllers and systems is shown here.
This cabinet is definitely one of the most comprehensive video game installations we’ve seen, and the display case of controllers looks fantastic. Check out a video of the system and some controller porn after the break.
Lots of Controllers
14 thoughts on “75 Controllers, One Gaming System
      1. It’s a controller made for the GameBoy Player on the Gamecube (like a super gameboy, but also played GBA games). Did you know you could also use an actual gameboy advance as the controller for the gameboy player?
Leave a Reply to nam-ereh-wonCancel reply
