Classic PDA Finds Second Life As A Network Touch Screen Display
pocketviewer
[Tomas Janco] had an old Casio Pocket Viewer PDA collecting dust. Rather than throw it away, He decided to re-purpose it as a display for time, weather, and the current status of his garage door.
The Casio Pocket Viewer was a competitor to the Palm Pilot. The two systems even shared the same LCD resolution – 160×160 monochrome. [Tomas’] particular model is an S660, sporting 6 megabytes of ram and an NEC V30MZ (Intel 8086 compatible) processor. Similar to Palm, Casio made an SDK freely available.
The SDK is still available from Casio, and [Tomas] was able to get it running on his PC. Development wasn’t without pitfalls though. The Pocket Viewer SDK was last updated in April of 2001. Software is written in C, but the then new C99 standard is not supported. The SDK does include a simulator and debugger, but it too is not as polished as todays systems – every simulator startup begins with setting the clock and calibrating the touch screen. Keep reading after the jump to learn about the rest of the hurdles he overcame to pull this one off.
The pocket viewer’s only connection to the outside world is through an RS-232 link. [Tomas] was able use the serial link to connect the pocket viewer to his server running custom PHP code. At first he tried to send full screens of data to the PV. This proved to be much too slow at serial speeds. Updating only those sections of the screen which have changed proved to be much faster. In the unlikely event that an entire screen has changed, [Tomas] sends the screen in chunks – so the user still sees activity at the display.
The finishing touch was a power source. The pocket viewer was designed to run on AAA batteries. [Tomas] installed a 3V regulator, but even then the system would reset randomly. The internal DC to DC converter of the Pocket Viewer was causing current spikes that his regulator couldn’t handle. A 100uf capacitor finally stabilized the power supply.
[Tomas] final hack was to add an interface from his garage door to his router. The router updates his server on the garage doors state.  The server then formats this information for the pocket viewer, letting [Tomas] know if the garage is open or closed.
We think this is a great example of reusing old hardware.  How many of us have an old PDA lying around?  It would be great to see more of them end up being use like this, rather than recycled or worse yet, sent to the landfill.
18 thoughts on “Classic PDA Finds Second Life As A Network Touch Screen Display
  1. I would love to rescue my old palm zire (original and z71 models). One of them has serial, the other has just usb (guess you could tap into the usb2serial chip).
    They’re been collecting dust for 5 years or so. Installing software was already a pain back in 2008, and most serial console programs are paid (but sells them anyway?)
    Any tips out there?
  2. I have 4 OLD Fujitsu Stylistic c-500 touch screen tablets that I picked up on eBay several years ago for $20/ea. They run Win2k. I bought them because I saw the potential of doing something like this but as of yet, haven’t done anything with them. This gives me some ideas.
  3. You can use “Pocket C” which is a C interpreter for both PalmOS devices and pocketPC devices. I have personally used it to write programs that talk on the serial port of a Palm device. The newer Palms with Multi connectors (newer Tungstens) don’t have serial ability but they do have IR ability to talk to other Palms.
    http://www.orbworks.com/pcpalm/index.html
    If you want faster compiled C, you can do some web hunting to put together the correct gcc compiler and libraries. I use the Falch.net compiler which assembles the gcc stuff, but that site is gone now :(
Leave a Reply to Stephen HartCancel reply
