A Simple Nixie Clock With Logic Gates
Here is a very nice project that [Znaxque] finished a few months ago: a simple nixie clock made with logic gates only. In this build, the mains 50Hz is used as a time base instead of a 32KHz crystal that most readers here may use. In the very long term, this clock may actually be more precise than a crystal-based one as power companies in Europe adjust the mains frequency. However, at a given moment the difference between this clock and a reference may be as big as 60 seconds.
The design was sketched on a simple piece of paper and later made using salvaged ICs. [Znaxque] only bought the six IN-14 nixies for $45 and the veroboard shown in the picture above. The BCD to Decimal decoders are 74141s and three buttons are present on the board to set minutes, hours, as well as resetting all the counters.
11 thoughts on “A Simple Nixie Clock With Logic Gates
    1. Oh noes! the clock will be out by max 1 minute.
      Let’s face it, you’re not going to use this clock for really time critical stuff where every seconde counts. And over half a year it will be a hell of a lot more stabil than a RTC IC with an average 32 kHz crystal.
      Ofcourse if you want nerd points (let’s face it, we all want those) use GPS combined with a rubidium standard. But then again that’s who needs that kind of precision from a normal desk clock?
  1. At first sight, that timebase seems convenient. However, in time, the clock will always be fast. The problem is that small interference spikes occurring around the zero-crossing point will add to the number of transitions (never subtract!) counted during the day.
    I suggest that the inverter should be slugged so that it will not respond during the time that it takes the AC signal to pass between the thresholds. I guess that a 20-30 ms time constant should do it.
  2. I’ve seen about a zillion Nixie Tube clock writeups all over the place… Can’t remember where it is, but if you ever see it, check out the one that the creator offers as a kit, complete with a hardwood box to put it in. I was amused.
Leave a Reply to jcgCancel reply
