Interactive Boozeshelf Is Its Own Dance Party
boozeshelf
[Jeremy] refused to settle on your typical alcohol storage options, and instead created the Boozeshelf. Like most furniture hacks, the Boozeshelf began as a basic IKEA product, which [Jeremy] modified by cutting strips of wood to serve as wine glass holders and affixing the front end of a wine rack at the base to store bottles.
In its standard operating mode the Boozeshelf lies dark and dormant. Approaching it triggers a cleverly recessed ultrasonic sensor that gently illuminates some LEDs, revealing the shelf’s contents. When you walk away, then lights fade out. An Arduino Mega running [Jeremy’s] custom LEDFader library drives the RGB LED strips, which he wired with some power MOSFETS to handle current demands.
[Jeremy] didn’t stop there, however, adding an additional IR receiver that allows him to select from three different RGB LED color modes: simple crossfading, individual shelf colors (saved to the on-board EEPROM), or the festive favorite: “Dance Party Mode.” Stick around after the break to see [Jeremy] in full aficionado attire demonstrating his Boozeshelf in a couple of videos. Considering blackouts are a likely result of enjoying this hack, we recommend these LED ice cubes for your safety.
9 thoughts on “Interactive Boozeshelf Is Its Own Dance Party
        1. Same problem with my point and shoot. Landscape cuts off the top and bottom when I get close enough to actually see the thing. I suppose if I had an SLR I could get a lens for that.
  1. It would be cool to take it 1 step further, and set the mood based on which alcohol you choose. For example, if you pick up vodka, the lights turn red, and it plays the Russian national anthem…
Leave a Reply to RyanCancel reply
