Unorthodox Home-made CNC Machine
PVC CNC Machine
Here’s a rather unorthodox home-made CNC machine we haven’t seen before!
[ModHappy] recently accepted a challenge to design and build a CNC machine out of cheap and readily available components from a hardware store.
Wandering around the store he noticed the plumbing isle and he started playing around with PVC pipes on the floor, greatly confusing the store employees. He had a frame constructed, but still needed a way to achieve linear movement. His calls were answered in the electrical isle, where he made use of conduit wall-mounts! They only required a minor modification to go from gripping the pipe, to sliding along it. A few fasteners later, some stepper motors from a broken scanner, a CD-ROM drive for the z-axis, some hacked together couplers using set screws, and the mechanical build was complete.
On the controls end, he made use of a cheap Chinese TB6560 CNC driver board off eBay, which he modified slightly to increase reliability. The whole thing runs off LinuxCNC (which is free) on his old laptop — good to note, it can also be run live if you aren’t yet enlightened with a Linux OS.
Stick around after the break to see it in action, drawing out an awesome site’s logo!
[Read more...]
Follow
Join 92,317 other followers
