Tricked-out Arduino-controlled Time-Lapse Is More Than Just A Timer
arduinoPhotoRig
[Hlesliebole] wanted a finer degree of remote control over his time-lapse shots, so he decided to build an Arduino-driven infrared shutter. He ended up creating this killer Arduino-controlled photography rig that does a whole lot more.
This hack was built for [Hlesliebole]’s Nikon D3100, but he says it should work with any DSLR and remote shutter. This initial build uses an LED as a stand-in for the remote shutter that he ordered.  He intends to update the post once it arrives and he integrates it.
[Hlesliebole] wired a 7-segment display to show the current time delay between photos. This can be set on the fly with a potentiometer, so there’s no need to stop and reprogram the Arduino. And while you’re grabbing a beer and watching the sun slowly sink, the rig can better capture that sunset because of a photoresistor. It detects the ambient light level and minimizes the number of throwaway dark shots.
If that weren’t enough, he’s built servo functionality into the code to support remote control over the camera’s physical position, allowing for panning or rotation over a scene. [Hlesliebole] doesn’t go into detail, but he assures us that there are many tutorials out there.  If you think you’re man enough, you could always work in this outstanding versatile motion dolly hack.
One thought on “Tricked-out Arduino-controlled Time-Lapse Is More Than Just A Timer
  1. I did time-lapse photography for one of my internships, and there is a way to do that without having to program/build with Arduino (love the concept though and will be investigating this).
    Some cameras are built with an intervalometer (a majority don’t and you need an external one) and you can use this to create a time-lapse video from the still images.
Leave a Reply to AllisonCancel reply
